purchased these here over a week ago!... got around to fitting my water-cooled set-up yesterday... however i had them nearly all fitted when i noticed one of them was tight..as in, it didn't feel like it wanted to fit into the CPU block after a go or two, i took it off to inspect...and try another one. to my surprise the tight one is black plastic and not steel/metal like the other 5.... i made sure threads where not effected and tried again as it was the last one to be fitted, i eventually got it on thou its tighter than the other 5 to fit. im disappointed i got one plastic with the 6pack..and im disappointed in myself for not returning
these..i was just too excited to wait some more weeks.
my question is has this happened to anyone else??? what should i do about this??? so far everything is fine (no leaks). will there be problems with the plastic???
i would appreciate any advice or help with this!
thanks!
thanks!
, and used pliers to forcibly make the miss threaded fitting cut into the plastic of the reservoir until it was water tight.
