Man of Honour
- 29 Mar 2003
- Blurton
Answer my question before you act like cat has got the cream![]()
Goes off to look for a question .................
If he wasn't... then that politician or newspaper would be done for slander.
The mere fact he hasn't pursued it further means he is not completely legit.
Or it means he doesn't care because a newspaper claiming he avoids tax, whether legitimately or otherwise will have absolutely zero bearing on his life whatsoever.
I have added a question mark to help you...
HMRC only go after the low paid working class for tax as it is easy for them to screw them over. If you have more money and can afford better lawyers, then you can avoid tax all you like as HMRC won't bother with you.
A flat rate can work, just not a low flat rate (as that would result in a huge deficit in public finances).
A flat 50% rate for everybody (with the government providing significantly more to off-set the balance), you could have a functioning system - but it may not be desirable.
You are completely correct about the rest mind.
Edit - on a side note, I don't think he should return his OBE mind - but I don't even think OBE's should even exist .....
Rubbish, a flat rate would not reduce tax avoidance.
People don't avoid tax due to some view on the morality of a variable tax system - they avoid paying tax because it yields them a greater amount of money, as long as large sums of money can be made avoiding tax, people will do it - regardless as to what a mythical flat rate was set at.
If it is about fairness, would you be happy with a flat 60% rate then across the board? - or let me guess, when you say "I want a flat rate" what your really mean is "I want to pay a lower rate than I do currently"?.
If you are worth millions and have nothing to do in-between albums then chairty work is where its at.
a: It makes you look good
b: It relieves Boredom
I mean Gary just can't sit in his big house all day can he?
Or like Elton...Just auction off all the **** you buy on a regular basis and give it all to charity.
I would be more inclined to celebrate the full time working mum that needs to work to eat that fund raises on a regular basis.
Just sayin
Ahem: http://en.wikipedia.org/wiki/Sing_(Gary_Barlow_album)I didn't see him releasing any songs when he helped arrange the Queen's Jubilee concert
I would like to congratulate Gary Barlows ACCOUNTANT on being smart with his money.
Corrected![]()
Children in need.
Celebrities in need of Ego boost.
Yet the contractor should be on an hourly rate that's x10 that of the PAYE worker.
I'll give you an example;
Project Engineer I work with. £450 a day. He's a contractor. Pretty much booked up till 2016.
Project Engineer working for a very very large civils multinational. £35k a year ...
But that 450 headline figure seems large but you forget
- he probably has to pay an accountant
- he has to have several insurance policies
- supply his own laptop / tools
- possibly doesnt live locally so has costs which he cannot pass to the client.
It's still all a cost to his business though.All of which are tax deductible...and it is a pretty poor accountant that doesn't save his client far more than he charges the client.
