17 Nov 2013 at 18:24 #1 shaun_a shaun_a Associate Joined 9 Nov 2013 Posts 70 Gigabyte Z87X-OC Asus Z87-PRO and the best ram to use is 2x8 or 4x4 better thks
17 Nov 2013 at 18:41 #2 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare Nothing under £250 beats a OC board.
17 Nov 2013 at 18:41 #3 Christmas themed thank Christmas themed thank Mobster Soldato Joined 9 Apr 2012 Posts 13,172 OC for sure.
17 Nov 2013 at 18:42 #4 Christmas themed thank Christmas themed thank Mobster Soldato Joined 9 Apr 2012 Posts 13,172 shaun_a said: and the best ram to use is 2x8 or 4x4 better Click to expand... Depends. Will you want to upgrade to 16GB later on? If so, go for 2x8. If not, then go for 4x4 as it should be cheaper.
17 Nov 2013 at 19:21 #5 shaun_a shaun_a Associate OP Joined 9 Nov 2013 Posts 70 Is the oc force worth the cost
17 Nov 2013 at 19:27 #6 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare shaun_a said: Is the oc force worth the cost Click to expand... Not if you wont be needing 3/4way SLI/Crossfire support.
17 Nov 2013 at 23:52 #7 los los Associate Joined 26 Jun 2011 Posts 2,438 Location Great Yarmouth If you don't have a dedicated sound card might be worth looking at the hero
18 Nov 2013 at 00:20 #8 Jasseh Jasseh Associate Joined 26 Jul 2012 Posts 1,340 Location England AlecR said: Depends. Will you want to upgrade to 16GB later on? If so, go for 2x8. If not, then go for 4x4 as it should be cheaper. Click to expand... 2x8 and 4x4 are both 16GB Z87X-OC, ordering mine in a few hours . Edit: Just ordered mine Last edited: 18 Nov 2013
18 Nov 2013 at 00:27 #9 d_brennen d_brennen Soldato Joined 30 Jan 2009 Posts 17,517 Location Aquilonem Londinensi E:
18 Nov 2013 at 16:40 #10 shaun_a shaun_a Associate OP Joined 9 Nov 2013 Posts 70 d_brennen said: E: Click to expand... ??
