BMW Financial Services - show up on credit report?
18 Oct 2002
Hi all,
Quick question for anyone who has leased / bought a car utilising BMW Financial Services.
Did their credit check show up on your credit report?
Thanks
[TW]Fox;25327834 said:
It will show the full outstanding amount including the interest due if you kept the agreement until the end of it's term.
Hi, not looking to see if it shows up on the credit report if i have one, just checking to see if the actual search shows up on your report.
I'm not seeing it on mine....although a card I applied for two weeks later is there.
Is this from experience of having bought one? I recall you had a Z4?
I've had 2 cars with them. I don't recall there being a credit check the second time but there definitely was one the first time.
As Fox says, it will show the full outstanding amount (including balloon if on a PCP). So, for example, if you PCP a £30k car with a £3k deposit and a £15k baloon, the outstanding amount shown on your credit file will be £27k+ interest.
Which credit agency are you checking with? There are three.
