I'm pretty sure but curious to know if anyone has any other thoughts.
Lately I've noticed the car taking a little longer to get up to temperature than normal but put it down to cold weather (city driving). However went on a longer run over the weekend and noticed the temperature gauge being at temperature but then dropping off so plugged in my OBD reader and temperatures dropped to as low as 56°C on the dual carriageway/A roads.
Coolant levels fine and warm air still coming into the cabin. At low speeds/in traffic it still gets up to temp. I was pretty sure it's the thermostat so blocked off a section of radiator with bin liner for the journey back and temps were about 15°C higher so significantly better if not quite right..
Thoughts?
Car in sig, MkIV Golf 2.8L
Thoughts?
so into the garage it goes..
