Check this spec pls
9 Nov 2013
Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor
Asus Z87-PRO
Asus GeForce GTX 660 DirectCU II OC 2048MB GDDR5 PCI-Express Graphics
Samsung 250GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE250BW)
Kingston HyperX Beast 16GB (2x8GB) PC3-12800C9 1600MHz Dual Channel Kit
Antec P280 Super Midi Tower Case - Gun Metal Black Antec P280 Super Midi
Corsair Enthusiast Series TX 650W V2 High Performance '80 Plus Bronze' High Performance '80 Plus Bronze' Power Supply (CP-9020038-UK)
Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW)
Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-02050)
Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM
Alpenföhn K2 Mount Doom CPU Cooler
OcUK 24x DVD±RW SATA ReWriter
Antec TrueQuiet 120 Blue LED 120mm
will be overclocked
Or go with gigabyte oc board
many thks
If you can stretch the budget I'd go for faster ram. Why the 2 different sized SSDs? I'd buy 2 of the same and set them up in a raid config if I could afford it.
Want 1 ssd for os 1 ssd for videos to be edited then put oh hdd
Is it worth having raid i might be wrong but if you get a virus dont it go onto both drives so what is the point ?
What ram is best and ur views on mb
Thks
Offers change on wednesday bud was there a budget in mind? We could come up with a few different ideas for you but it will all change come wednesday
YOUR BASKET
1 x intel core i7-4770k 3.50ghz (haswell) socket lga1150 processor - retail £251.99
1 x gigabyte radeon r9 270x windforce 3x oc 2048mb gddr5 pci-express graphics card £155.99
1 x gigabyte z87x-oc intel z87 (socket 1150) ddr3 atx motherboard £149.99
1 x samsung 250gb ssd 840 evo sata 6gb/s basic - (mz-7te250bw) £146.99
1 x adata xpg xtreme v1.0 16gb (2x8gb) ddr3 pc3-17100c10 2133mhz dual channel memory kit (ax3u2133xw8g10-2x) £129.95
1 x antec p280 super midi tower case - gun metal black £99.95
1 x antec high current gamer 750w modular '80 plus bronze' power supply (0-761345-06223-7) £99.95
1 x microsoft windows 7 home premium sp1 64-bit - oem (gfc-02050) £79.99
1 x samsung 120gb ssd 840 evo sata 6gb/s basic - (mz-7te120bw) £79.99
1 x seagate barracuda 2tb 7200rpm sata 6gb/s 64mb cache - oem (st2000dm001) hdd £65.99
1 x thermalright silver arrow sb e extreme cpu cooler ty-143 fans £53.99
1 x liteon ihas124-14 24x dvd±rw sata rewriter (black) - oem £11.99
total : £1,348.16 (includes shipping : £17.85).
so you are not going for the "quantum" overclocked bundle any more i take?
the above spec i have altered for you is much better, if you want to save more money then you can use this win8.1 trial for 90 days - http://technet.microsoft.com/en-gb/evalcenter/hh699156.aspx
• the gfx card is faster in gaming see here., it lacks CUDA but you get OpenCL acceleration in many apps.
• The PSU is modular and has the power for a pair of these cards.
Hi all dont no what to do like some of the spec of the asus board
And only changed from the quantum bundle cus i changed board and fan cooler
Help ?
You can add a Wifi/Bluetooth card later.
The OC is the better board, nothing comes close to clocking like it does in this price range.
CUDA helps, but so does OpenCL which the ATI has.
Edit, OpenCL is actually an open platform for all cards to support, CUDA is Nvidia only.
Like the wifi and bluetooth
Or is the gig a better board
And someone said that cuda helps in editing?
Thks
The OC is a good mobo, especially for OC`ing. But you need to decide what you need from the board.
Compare both boards, look at the features and the connections they offer. Then get whichever meets your needs and requirements. What other devices are you likely to connect to your mobo?
No point in buying a mobo with lots of fancy features, if you`re not likely to ever use them.
The quantum would take the pain of overclocking away if you've never done it yourself.
Maybe work out the cost of the individual parts and compare against the bundle cost to weigh up if its worth it to you.
check this nearly there
Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor -
Gigabyte Radeon R9 270X WindForce 3X OC 2048MB GDDR5 PCI-Express
TeamGroup Xtreem LV 16GB (2x8GB) DDR3 PC3-17000C11 2133MHz Dual
Gigabyte Z87X-OC Intel Z87 (Socket 1150) DDR3 ATX Motherboard
Antec High Current Gamer 750W Modular '80 Plus Bronze' Power Supply
Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (
Thermalright Silver Arrow SB E Extreme CPU Cooler TY-143 Fans
NZXT Sentry LXE Touch Screen External Fan Controller
Fan Antec TrueQuiet 120 Blue LED 120mm Fan x2
LiteOn IHAS124-14 24x DVD±RW SATA ReWriter (Black) x2
Total : £1,456.08
:D
might go with the Quantum but change the fan to the one above
