New build
26 Jul 2013
England, Bromsgrove
Looking at a new build now that i have passed my driving test
http://www.overclockers.co.uk/showproduct.php?prodid=MB-576-AS
http://www.overclockers.co.uk/showproduct.php?prodid=CP-337-AM
http://www.overclockers.co.uk/showproduct.php?prodid=MY-039-AR
Or
http://www.overclockers.co.uk/showproduct.php?prodid=MY-068-PA&groupid=701&catid=8&subcat=1517
http://www.overclockers.co.uk/showproduct.php?prodid=MY-093-PA&groupid=701&catid=8&subcat=1517
I have everything else
Artic 750watt psu
1 SSD
2 HDD
His IceQ 7950
H60 and many many fans
Just wondering if its worth me spending that much on a mobo or stick to the ones around the £100 mark, i will be upgrading the psu for a second GPU a later on down the line as well
(inb4 intel) im after an AMD set up not intel
Cheers
John
Not that i was going to suggest it, but why?
It just casts a bit of naivity over your post..
Does it actually benifit your uses going AMD or is it because it fits into your budget better? if so, what is your budget?
Ahhh dosent matter now, talked my self out of upgrading again until steamroller comes out
