Alternative title by Neil the Hippy:  There's a hole in my wall (and it's letting out money).
I've always known that my kitchen is considerably colder than the adjacent living room, but I'd idly assumed that it was down to a combination of two external doors, a large single pane window and being an extension.
While cleaning out the gutter one day, I happened to be at the right angle to be able to see through the wall into the kitchen. Somehow, I had avoided paying any attention to a fairly large hole in the wall, covered by slatted vents each side. The inside is in an alcove where the boiler is, high on the wall, almost flat to the wall and painted the same colour as the wall, so it's not immediately obvious.
I'm almost sure that it's a vent for a different type of heating from long ago, because I'm almost sure that for years boilers have been sealed from the room and don't need external venting on the wall next to the boiler. The boiler has its own venting to outside - this is a hole in the wall about a foot to the side of the boiler, not connected to it at all.
So unless someone who knows something I don't says the extra vent is a useful safety measure, I'm going to block it up. What would be the best way to do it? I was going to use that expanding spray foam filler, which should be easy, but I'm thinking that's probably not much good for thermal insulation.
