Unless you're running DOS games, you won't be running single threaded games. Newer ones are using 8 cores, and it can make a big difference there, especially overclocked.
Having looked at the benchmarks, the difference between the FX6300 and the FX8320 is definitely there. However it is simply out of budget, the budget is extremely tight and squeezed as it is, and I simply can't stretch to chase diminishing returns in performance.
EDIT: thankyou for the free shipping, I do not know if my friend will want to order through my account or not.
They're both 900 series. The only difference between 970 and 990 is with multi GPUs.
The Asus 970 board is known to overclock extremely well, much more so than the Gigabyte, and you should reach 4.5GHz or better with the cooler I suggested.
Definitely agree on R270(X), the FX-6300 is not a bad choice, even though the FX-83xx is better in multi-threaded games and applications. As stated, it comes down to budget. Oh and I would go for a 990X board too.
