- 1 Apr 2010
If you plan to keep your new chip as long as you kept the Q6600 then the extra $100 (£60) isn't a big outlay, go for the 4770K.
Yep, should be fine if your using vsync. Also at 2560x**** res bottlenecking wont be as big an issue. Interesting article here where it states that even a 3770k at 4.5ghz bottlenecks the gtx 780ti in a few games at 1920x1080.+1 As above, but would add that even an Ivy i5 at 4.7Ghz doesn't bottle neck 2x7950's in BF4 Max settings.
But most i5's only hit 4.5Ghz so it wouldn't be a good choice if sli/crossfire is your goal. (Unless Mantle changes the cpu overhang).
I hope you mean the 4670k will bottleneck high-end dual GPU setups, because there has been no data saying that it will bottleneck any single card, especially with a mild OC like 4.2ghz that's achievable for anyone.
.The Q6600 has probably been the most "future proof" chip to date (if i can use that term). I bet there's still quite a few people happily gaming on their oc'd Q6600 rigs today.
I still have a Q6600 and Q6700 in use today along with another chip which has also stood the test of time the i7 920.
future proof from what? its such a silly term.
as said games are going to be 90 percent made for the new consoles which have a less powerful cpu than a i5 now it isnt going to increase.
by the time you need a newer cpu youll be upgrading anyway to a newer platform.
wait for mantle lets see how that fairs then decided.
DG sprouting garbage as normal
http://www.kitguru.net/software/gaming/matthew-wilson/nfs-rivals-double-the-frames-double-the-speed/
Just to let you know, it's not always a good idea to look at console ports for advice..
Nothing related to this thread. OP made a good choice, as he clearly can afford it.
Hi all, I upgraded from an I5 3570K to an I7 3770k and to be honest I have noticed no difference at all. Do I regret it ? No not really as I like spending money on my PC.
Most games won't perform any differently between an i5 and an i7, whether it's one GPU or two makes no difference inherently. If a game uses multiple threads and is demanding on top, then it makes a difference.
Sandy however will give a bandwidth bottleneck with two GPUs, so a 2500K to 3770K will make a difference.
em...not for Crysis 3
I have a i5 3550 (stock) with 7990, High setting is smooth, but very high is a bit laggy...
Overclock it then and re-test. Definitely a bottleneck.
i5 3550 and a 7990.... That's going to be a bottleneck.
i5's and higher end multi-gpu set ups in some of these decently threaded games aren't that great, especially at stock.
