- 23 Oct 2013
Hi everyone I've just brought some 60cm akasa strip lights and there longer then I need is it possible to cut them down with them breaking? Thanks
Yes they will have some scissor marks where you can cut them to the length that you want. I have cut about 10cm off the end of mine so it would fit in the top of my case.
thats good to know then, it looked like that was what the line was for. i just wish it came with a longer cable.
