Point is that if all the available software actually took adavantage of all the cores available then we wouldn't really need continuous advancment in terms of CPU's.
The only reason for Haswell was laptops and tablets. It focused mainly on a better IGPU. There was no reason at all to switch from Ivy to Haswell but people did it any way.
I don't know if they thought that Intel had designed Haswell for them or for what reason you would change but hey, it worked. I would bet the numbers were much smaller than those doing the pointless upgrade from Sandy to Ivy though as Haswell came with problems (heat mainly).
If Intel really wanted to it could push the software developers to work harder at using more cores. But Intel don't want that as their mainstream CPU is quad core. Why spend money pushing people to use eight cores when you only offer four plus HT as your highest spec desktop CPU?
