You could play BF2 with less specs and have a far better experience, just saying.
A new GPU would be a good move, something like an R9 280X would be ideal. (If you want to stick with nvidia then I wouldn't advise getting anything with less that 3Gb of Vram)
What OS are you using? Upgrading from windows 7 to windows 8 / 8.1 also give a good performance upgrade for systems that can make use of direct x 11.1
Are you sure the crashing is because of you and not Dice?
Win 7 64 bit.....
It seems I would prob need to spend about £200-£250 on a new GPU ?
I've heard AMD/Radeon is superior to Nvidia at least for BF4 ?
 I'm yet to see a 780ti beast my 290x.new gpu oc your cpu
Your best bet is AMD for a cheap card, but the 780ti is far more powerful than anything AMD have... for now.
What would be the best upgrades I could make ?.
