It'd be far better to aim for two 780s than get a very expensive version of the 780ti -- given that the 780 is barely behind, and a single 780ti still can't cope with maxed out settings in the most demanding games.
Tested, tested for a dose maybe...
There is no way 3GB VRAM is enough for 4k.
I'm playing Battlfield at 1440P and with Shadow Play enabled I'm hitting my VRAM limit occasionally.
And every time you hit the Vram limit do you get an insane stutter where it buffers Vram to the HDD and it turns unplayable for a few secs?
No? Maybe the only reason you notice it hitting the limit is because you are looking for it.
If it doesn't make a difference..
These cards have been tested even in 4K and they cope just fine.
I'm playing Battlefield at 1440P and with Shadow Play enabled I'm hitting my VRAM limit occasionally.
Are you running at 4K Gripen?
Oh no... that won't happen until some time 2016. I don't see the bigger need for such a high pixel density on only 27~29" screens yet.
But I have been running 7680x1440p for about a month while doing some reviews for a HW site.
Actually the frame rate did plummet. I hit 3030MB and performance canned it. I think Shadow Play running also contributed. But BF4 will use 2800MB+ with maximum settings when 3GB is available.
Anyone who thinks 3GB is enough for 4K is kidding themselves all the way to the bank.
