I've just finished fitting a Prolimatech MK-26, with Akasa Apache 140mm fans, on my 290 and the results are great, but there's been a few headaches.
I did a few tests before I got stuck in. I found my MSI 290 had Hynix memory and the stock temperatures are as follows:
GPU idle - 36c
VRM 1 idle - 21c
VRM 2 idle - 28c
GPU load - 94c
VRM 1 idle - 60c
VRM 2 idle - 81c
The results after fitting the MK-26 are:
GPU idle - 30c
VRM 1 idle - 19c
VRM 2 idle - 22c
GPU load - 54c
VRM 1 load - 57c
VRM 2 load - 39c
First off, the glue that comes with the Alpenföhn heatsinks is horrible. DO NOT use it. It drys quickly and becomes really brittle, the sinks kept coming off as the glue cracked. I tried using both small and generous amounts of the glue and had the same results. I used Akasa thermal tape in the end.
There was quite a big headache with regards to how sensitive the PCB was. It was obviously sagging quite a lot, so I supported it so that it was a straight line, it wouldn't work like that. I'd black screen, crash and would have to wait 10 - 15 mins to use it again. I discovered the best thing to do was support most of the weight but let it sag a little.
I also tried the fans on both ways, drawing air away from the heatsink and blowing air onto the heatsink. Drawing air away had the GPU load at 80c, blowing air onto it is as above. Far more effective.
Here's some before and after shots, compared to a 7970.
GPU idle - 36c
VRM 1 idle - 21c
VRM 2 idle - 28c
GPU load - 94c
VRM 1 idle - 60c
VRM 2 idle - 81c
GPU idle - 30c
VRM 1 idle - 19c
VRM 2 idle - 22c
GPU load - 54c
VRM 1 load - 57c
VRM 2 load - 39c
