[windows 8.1] right clicking on a hard drive in file explorer causes crash
18 Mar 2010
I am running a clean install of windows 8.1
If I right click on a hard drive in file explorer, then file explore will crash. It just closes down.
Right clicking on folders is fine.
I have seen a few solutions posted online, and I would first like to check my crash log to confirm whether mine is the same problem. Where will I find a crash log?
(note this is nothing to do with autodesk - i know that has caused explorer crashes but i don't have that installed)
I suspect it could be something to do with link shell extensions that I am using on my computer, and have not installed on my parents computer, as they are not having this problem.
http://schinagl.priv.at/nt/hardlinkshellext/hardlinkshellext.html#faq
Clean install = no programs installed.
Install CCleaner, this has an option to remove right click entries.
A good rule of thumb is to never install any at all.
Personally, I allow the 7-zip one, that's it.
^ No problem.
Yes - is that known to cause issues?
Yes, it's to do with the "Windows Explorer integration (64-bit)" option that allows Spybot to appear in the right-click context menu. You just need to deactivate/uninstall that function within the Spybot interface.
However, Spybot 2 is a complicated mess now anyway so uninstalling the whole thing, as you have, is probably best.
