Suggest a replacement for my Corsair H80 Stock Fans for £10 or less
7 Feb 2011
As per title - the stock fans on my H80 are so loud that I cannot bear to have the speed set on anything but LOW.
Don't want to spend a fortune, but would happily replace the stock fans (and use them as 2 extra case fans instead - so at least they won't be wasted)
I run push pull as an exhaust at the moment and I do overclock my AMD 8320 (currently 4.2Ghz, but I'm sure it could get much higher if correctly cooled)
There are loads of other threads that refer to the same thing, but would be good to get everyone's opinions in a single thread
Thanks.
sp120's I have them on my 80, they are good, and quiet.
simples
Just read this:
http://www.anandtech.com/show/6177/...or-fan-testing-eight-fans-with-corsairs-h80/6
"Regarding the Corsair H80 specifically (and presumably the rest of their line), you're probably best off just sticking with the stock fans included with the radiator as they provide a competitive blend of performance and acoustics."
I can't see much of a case for changing from the stock fans - can you?
