<<<<< BLACK FRIDAY DEALS: AMD GRAPHICS CARDS!! >>>>>
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Right some whopping savings on AMD Graphics cards, the star of the show is the MSI 7850 2GB with over 40% discount and typically a good 30% cheaper than all our competitors. PLUS IT EVEN INCLUDES ONE FREE GAME TOO:-
MSI HD 7850 OC 2048MB GDDR5 PCI-Express Graphics Cards @ £89.99 inc VAT
With continued demand for increased graphics horsepower to support more visually intensive games, the AMD Radeon HD 7800 Series is set to power the next generation of games and applications. And for those looking to upgrade to a next-generation graphics card, the AMD Radeon HD 7800 Series is the ideal choice.
Features:-
- Core Clock: 900MHz
- Memory: 2048MB GDDR5
- Memory Clock: 4800MHz (Effective)
- Processing Cores: 1024
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 1 Dual Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Warranty: 3 Years
Was [£125.99] Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
HIS HD 7850 iPower IceQ Turbo 4096MB GDDR5 PCI-Express Graphics Card @ £139.99 inc VAT
This HIS 7850 IceQ is a very special card and one which is exclusive to OcUK. Built using a 7870 PCB and the IceQ cooler from the 7870 this card has truly immense OC potential. Not only that but in its quiet mode the card operates in near silence. There is no better 7850 on the market and exclusively available from Overclockers UK.
With IceQ, the card is up to 20 °C cooler than the Reference Cooler. The super large 80 x 21.5mm single blower fan draws massive amount of cool air to cool the GPU directly. The fan is equipped with 2 ball bearing and is extremely durable with a life span of 50,000 hours! 4 wide heatpipes optimize cooling performance by removing heat from the core area. The extra large 35 x 30mm copper heatsink provides a large heat dissipation area. The card also features fan control and fan monitoring, you are able to read fan speed & Asic temperature from CCC or software. IceQ is one of the quietest coolers. The card is below 28dB dB when watching movies, surfing Facebook, working. The card is quiet in 2D mode and remains quiet whether you are gaming, online socializing, entertaining or working.
iTurbo is your software assistant to control your graphics card to be quiet, cool and experience overclocking by simply pressing the iTurbo Button! User Friendly Overclocking Software: Cooler, Quiter, OC!
iTurbo's Fan Control and Fan Monitoring allow easy adjustment of your card to its maximum cooling performance or to run your card quietly! Press iTurbo: OC Right Away! With the smart auto overclocking function, users can experience a slight performance boost for HIS selected graphic cards with just one click! Powerful Overclocking Software: Either you wish to unleash its full potential or to make it more environmental friendly, iTurbo is ready for you!
IceQ ensures effective cooling when there is another card in front blocking the fan inlet, such as in CrossFire setup. By expelling the hot air, IceQ removes all the heat generated by the GPU out of the computer chassis, prevents the hot air from accumulating inside and enhancing the overall stability. The more crowded the chassis, the greater will be the impact.
The demonstration shows that the IceQ does outperform the 3rd party cooler in closed environment. Cool air is drawn from both sides of the fan and hot air is forced out of the computer case. This ensures effective cooling when there is another card in front blocking the fan inlet, such as in CrossFire setup.
Black hole impeller ensures large amount of cool air is ready. It draws cool air from both sides of the fan even there is another card blocking the fan inlet on the front side of fan.
IceQ is one of the quietest coolers, making the card 8dB quieter than the reference cooler. The card is below 28dB when watching movies, surfing Facebook, working. The card remains quiet whether you are gaming, online socializing, entertaining or working.
Features:-
- Core Clock: 1000MHz
- Memory: 4096MB GDDR5
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Was [£199.99] Inc. VAT
Only £139.99 inc VAT.
ORDER NOW
Asus Radeon R9 290 "Voltage Unlocked" 4096MB GDDR5 PCI-Express Graphics Card @ £309.95 inc VAT
AMD Radeon R9 290 is a new graphics card powered by the latest AMD Radeon™ R9 290 graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290 also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:-
- Radeon R9 290
- GPU: Hawaii Pro
- Stream Processors: 2560
- Core Speed: 947MHz
- Memory Speed: 5000Mhz
- Memory interface: 512-Bit
- Memory capacity: 4096MB GDDR5
- Cooling: 2-Slot Blower Fan
- PCI-Express X16 lane required
- 750W or greater PSU required
- Power Connectors: 8-pin + 6-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Warranty: 3yr
Was [£349.95] Inc. VAT
Only £309.95 inc VAT.
ORDER NOW
Sapphire Radeon R9 270X Boost OC 4096MB GDDR5 PCI-Express Card @ £169.99 inc VAT
The "dual" in Dual-X refers to the two highly advanced cooling fans that are coupled with multi-heatpipe technology to cool mid-to high-end graphics cards. The fans are amazing: each blade boasts a sleek airfoil shape that increases cool air throughput so they can run slower. Even when you're pushing the processing power to the limits. Even when your're overclocking.
The quiet-running fans work with multi-heatpipes and heatsinks that take away heat from the processor to the fans. Plus, dust repelling bearings radically reduce failure caused by the build-up of dirt. In short, its a quiet, efficient way of cooling your graphics card - even when you're pushing it to the limits.
Specification:-
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- Hugely overclockable
- Core Clock Speed: 1020MHz
- Core Boost Speed: 1070MHz
- Shader Architecture: GCN
- Stream Processors: 1280
- Frame Buffer / Memory: 4GB GDDR5
- Memory Width / Speed: 256 bit / 5600MHz
- Power Connectors: 6-pin + 6-pin
- Display Outputs: 2x DVI + 1x DP + 1x HDMI
- Power: 180W TDP
- 2yr Warranty
Only £169.99 inc VAT - STOCK DUE MONDAY - PRE-ORDER ONLY PRICE!!!
ORDER NOW
Sapphire Radeon R9 270X Vapor-X OC 2048MB GDDR5 PCI-Express Card with BattleField 4 PC Game Included @ £155.99 inc VAT
High-end graphics card use more power, which means they get hotter quicker. With the innovative Vapor-X, we were the very first to apply aerospace-industry vapor chamber technology to graphics cards. It's a pioneering way to accelerate heat away from the graphics chips into the rest of the cooling system.
Sapphire Vapor-X technology is used in conjunction with a heatpipe and fan assembly. The vapor chamber accelerates the heat away from the graphics chips into the rest of the cooling system. How? Inside the vapor chamber, a liquid coolant is vaporized at the hot surface. The resulting vapor moves across the chamber where it condenses at a cooled surface. Then the liquid is returned to the hot surface to aid in superior cooling.
Features:-
- 2nd generation Vapor-X technology
- Factory overclocked
- Quiet and efficient cooling
- UEFI support
Specification:-
- Core Clock Speed: 1050MHz
- Core Boost Speed: 1100MHz
- Frame Buffer / Memory: 2GB GDDR5
- Memory Width / Speed: 256 bit / 5800MHz
- Power: 180W TDP
- 2yr Warranty
- Exclusively ONLY at OcUK we also give you BF4 with this card
Was [£173.99] Inc. VAT
Only £155.99 inc VAT.
ORDER NOW
Some whopping savings there, these deals end on Monday midday or when the stock runs out, whichever comes first, so get your wallets out. :D
Im confused now.
Im putting together a budget build for my other halfs Christmas present.
with an amd fx 6300, I was going ati for graphics as well. I was thinking 7870/r9 270 but now with an 7850 @ only £90 is that the best bet? It will be a gaming build.
So do I go:
7850 for £89.99
http://www.overclockers.co.uk/showproduct.php?prodid=GX-221-MS
or is it better to get
R9 270 for £134.99
http://www.overclockers.co.uk/showproduct.php?prodid=GX-339-SP&groupid=701&catid=56&subcat=1982
or get a full r9 270x for £155.99
http://www.overclockers.co.uk/showproduct.php?prodid=GX-326-SP&groupid=701&catid=56&subcat=1982
HELP :P lol
Im confused now.
So do I go:
7850 for £89.99
R9 270 for £134.99
HELP :P lol
I was wondering that too. My 6870 is dying, crashes out of games within a few minutes, which has spoiled my gaming experience.
I would be getting BF4 too.
R9 270 4GB or R9 270X 2GB for single card? Baring in mind my spec in my sig. Resolution is 1920*1080
Im confused now.
So do I go:
7850 for £89.99
R9 270 for £134.99
HELP :P lol
7850 is marginally slow than 270, but way way cheaper! And I just changed it to now also include a SILVER code too, so now it comes with THREE FREE Games!!!
. Not much difference between it 270 and an x version to be fair
The 7850 is a bit slower but for the price i would say go with that one
With free games the 7850 is an insane bargain
Out of a 4 gig 270 and a 2 gig 270x get the 4 gig
Ooh decisions - I can get a 7850 + some games + BF4 (~£30) for £120 or a R9 270 X with BF4 for £35 more.
Tempted to go with current gen seeing as my 6870 dies on any game. I was hoping to jump across to Nvidia but this offer seems good.
ordered a 7850 and a few other bits for the Christmas present build. Hope I made the right choice.
The system it replaces is an old 1st gen core 2 intel with a gtx 9800
going to a fx6300 with 7850 so I think it should be a noticeable improvement :)
Im confused now.
So do I go:
7850 for £89.99
R9 270 for £134.99
HELP :P lol
The 270 and 270X cards are just 7870s rebranded. The 270 can't overclock really so I wouldn't bother, and the 7850 overclocked is the same speed as a stock 270X for almost half the price :)
