Adapter to power on two PSUs at the same time?
1 Sep 2007
Santa Monica, California
I am adding a dedicated gfx card PSU to my PC - I need some kind of adapter so they both power on at the same time? Does OCUK sell such a thing or anyone know a name of such a device I can google for?
Thanks!
One came with my old case which I sold to someone on here as they couldn't find one either so I assume you will struggle too. They are quite simple though so have you considered making your own?
I've thought about it. Maybe I should check the box my case came in as it supports two PSUs! Xigmatek Elysium.
'Dual PSU adapter' brings up a lot of results but everywhere I could find was in America.
Mine came with a TJ07 as they can take dual PSU's so might be the Elysium contains one too.
It's only bridging two pins on the 24 pin cable. The schematic can be found online if you don't mind getting your hands dirty
e: Use 24 pin extender cables to avoid binning warranty on the PSUs ;)
