- 10 Jan 2012
The scratches might be normal but impossible to know without seeing them. The logo is clear plastic, I doubt they were worried much about using 100% scratch free material.
If your not happy with it, I'd just return it
I'm not happy. What do you guys think of the Gigabyte 780 Ghz edition? I've never owned a gigabyte card ever.
Looks like a great card, and a nice price. Though it's factory overclock is lower than your Inno3D.I'm not happy. What do you guys think of the Gigabyte 780 Ghz edition? I've never owned a gigabyte card ever.
Classified out of those 2
The Classified is nice, though be aware it will run hotter and louder than your current one.
I chuckled
It's pretty good, but it can't compete with the Inno3D due to the size.
In a room of reasonable temperature it will run at around 70C.
Could I OC it to match or go over the Inno3D card?
Shouldn't be too much of a problem. Mine runs at 1150Mhz just by increasing voltage and power limit.
In your opinion what's the best 780 Neil?
When you were tying to overclock the card did you adjust the voltage/power limit? If not then you're obviously not going to get very far...
I have the 780SC in my lads set up and it performs well and runs cools.
As for the best - I'd say the Classy as it seems to perform the best from what I've read.
The only problem is what mem is on the card you get, which obviously effects performance to some degree.
If your not going to watercool and overvolt/clock, you won't get the best from the card.
If the above is of no interest to you, just get the cheapest you can find.
