memtest86
I generally do 3 passes, however long that takes. Most issues will be found first pass anyway, but more passes gives more confidence basically. I get bored so not more than 3 for me :)
Thanks, I will stop the test now. Unfortunately I can't see the right side of the screen but will memtest86 display my errors when I get back on Windows? I will show you a screenshot of my screen, I will let my PC rest aswell, it has been running for 27 hours reading patterns.
EDIT:My phone can't charge, charger is broken. Guess I will have to lift my laptop and take a picture with Webcam.
EDIT: Webcam not working, I suspected that years ago, guess I have nothing to show you my screen
You'll see an error within 2-3 passes if there's any problem.
Memtest86+ runs in VGA mode and is as minimal as possible to rule out anything but the memory, there's no way to save screenshots, etc.
I use 2 passes for initial testing and then do 3 when I think I've got the final settings I'm going to use, rarely any usefulness doing more than that and in 80% of cases it will fail in the first pass if its going to fail.
