- 22 Jul 2007
- nottingham
My Corsair AX1200i is silent only hear the fan on pc turn on then its silent.
Wow this thread escalated quickly!
He's going with a 850w unit![]()
If its the corsair rm850 that's on sale.. beware. It's likely one from the faulty batch with the broken OTP protection
Yeah, not a good choice. It's cheap for a reason.
http://www.corsair.com/us/blog/rm750_and_850_thermal_issue/
Corsair say it only happens in high ambient but theres been reports of it happening at normal room temperature. If your system causes the psu to run at moderate load (stressed but not enough to engage the fan) then it will shut down eventually due to overheating.
For a 100 pound budget I'd recommend the Seasonic G-750.
Says they sorted the issue
