** THE FIRST NONE REFERENCE 780Ti IN STOCK: GAINWARD PHANTOM!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
We've had our first none reference 780Ti arrived, with the amazing more or less SILENT Phantom cooler:-
Gainward GeForce GTX 780Ti Phantom 3072MB GDDR5 PCI-Express Graphics Card @ £599.99 inc VAT
NVIDIA's latest Geforce 780Ti takes the fight right to the competition in the battle for current worlds fastest single GPU. Packing a fully enabled GK110 GPU with a whopping 2880 cuda cores this card has huge amounts of processing power to enable it to power through any game. Infact the 780 Ti is so impressive, it’s not just cheaper than TITAN, it beats it in performance and takes the crown as the Best Gaming GPU on the Planet.
NVIDIA are supporting the overclocking community even further with an advanced three rail PWM with load balancing, whereas older GTX 780 and Titan pulled all their power through three rails, they did not load balance. 780Ti's new PWM means it can source power from three sources and load balance resulting in the same amount of power from each rail, allowing for more superior overclocks and stability. Here at Overclockers UK we tested this and where we found Titans would top out at 1100-1150MHz core, whereas the 780Ti was able to hit 1200-1300Mhz core over and over again, proving this new PWM not only offers efficiency and stability, but also great overclocking ability. When overclocked this cards performance can be increased by upto a further 30%, making it a truly unstoppable force.
For memory once again here at Overclockers UK we are very impressed to see 3GB of RAM and a 384-Bit interface meaning it can power the latest games even at the highest resolutions and detail settings, making this card the perfect choice for any gamer or overclocker.
780Ti uses the Titan cooling system and this means that even whilst gaming, you can indeed game in silence or at night whilst the rest of the household is asleep and not have to worry about waking up those sleeping.
Specification:-
- GeForce GTX 780Ti
- GPU: GeForce GTX 780Ti (GK110)
- Core Base Clock: 980MHz
- Core Boost Clock: 1046MHz
- Memory Clock: 7000MHz
- Memory Size: 3072MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2880
- DirectX 11.2: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
Only £599.99 inc VAT.
ORDER NOW
Just arrived too:-
Gigabyte GeForce GTX 780Ti WindForce 3x OC 3072MB GDDR5 PCI-Express Graphics Card @ £619.99 inc VAT
nonl2br
<p align="left">
GIGABYTE, the world leader in high-performance gaming hardware and system, is pleased to announce the latest graphics card, GeForce GTX 780 Ti Overclock Edition (GV-N78TOC-3GD). With 25% plus CUDA cores than GTX 780, the most powerful thermal design in the world and exciting new technologies, GV-N78TOC-3GD is going to bring all the gamers an extremely gaming experience to a whole new level. The exclusive WINDFORCE 3X cooling design guarantees you to dissipate 450 watt heat out. Enjoy your game play with a stunningly beautiful and quiet design is no longer a dream. It also supports OC GURU II and GPU Boost 2.0 for maximum clock speeds. GV-N78TOC-3GD features PhysX® and TXAA™ technologies for smooth, sharp graphics, and GeForce ShadowPlay™ to capture all your greatest gaming moments automatically. Whether you play on 4K monitors at extreme settings, GV-N78TOC-3GD can provide the horsepower to drive all your next-gen gaming visual experiences.
</p>
<p align="left">
GIGABYTE innovatively presents WINDFORCE 3X 2-SLOT cooling system, thinner and cooler! The thermal structure contains three ultra quiet PWM fans, an only 2-slot height heat sink with exclusive "Triangle Cool" Technology, two 8mm and four 6mm cooper heat pipes and a high-performance RAM heatsink.
</p>
<p align="left">
The innovative thermal design guarantees the heat dissipation capability to over 450watt. The cooling performance is 14% significantly better than stock fan! WINDFORCE 3X 450W cooling system not only provides an effective heat dissipation capacity, but also gained a higher performance with lower GPU temperature through the GPU Boost 2.0 technology.
</p>
<p align="left">
According to the latest NVIDIA® technology, GPU BOOST 2.0, GV-N78TOC-3GD provides gamers an unlimited overclocking capability. By using GIGABYTE exclusive OC GURU II, gamers can monitor and adjust all important settings such as GPU clock, memory clock, fan speed, voltage, power target, OSD and online support. With the upgrade and easy-to-control user interface, GIGABYTE OC GURU II becomes the best mate while using GV-N78TOC-3GD.
</p>
<br />
<center>
<object width="640" height="360"><param name="movie" value="//www.youtube.com/v/OHlQnKTvGms?version=3&amp;hl=en_GB&amp;rel=0"></param><param name="allowFullScreen" value="false"></param><param name="allowscriptaccess" value="always"></param>
<embed src="//www.youtube.com/v/OHlQnKTvGms?version=3&amp;hl=en_GB&amp;rel=0" type="application/x-shockwave-flash" width="640" height="360" allowscriptaccess="always" allowfullscreen="false"></embed></object>
</center>
<br />
<br />
<p align="left">
<h1>Specification</h1>
<b>GeForce GTX 780Ti</b><br />
- GPU: GeForce GTX 780Ti (GK110)<br />
- Core Base Clock: 1020MHz<br />
- Core Boost Clock: 1085MHz <br />
- Memory Clock: 7000MHz <br />
- Memory Size: 3072MB GDDR5<br />
- Bus Type: PCI Express 3.0<br />
- Memory Bus: 384-bit<br />
- CUDA Cores: 2880<br />
- DirectX 11.2: Yes<br />
- DVI Port: DVI-I /DVI-D<br />
- DisplayPort: Yes <br />
- HDCP: Yes<br />
- HDMI: Yes<br />
- Warranty: 3yr
</p>
<p align="left">
<b>Features</b><br />
- MAX your overclocks with NVIDIA's Power Balancing<br />
- A WHOPPING 2880 CUDA Cores (Fully enabled GK110)<br />
- GPU Boost 2.0 Technology<br />
- TITAN cooling system
</p>
Only £619.99 inc VAT.
ORDER NOW
Ocuk surprisingly seem to be playing catch up as far as the non reference 780ti's are concerned...I received a EVGA 780ti SC ACX last week (Thursday), would have bought here (even at the slightly higher price) but no stock...and still no stock I see.
Ocuk surprisingly seem to be playing catch up as far as the non reference 780ti's are concerned...I received a EVGA 780ti SC ACX last week (Thursday), would have bought here but no stock...and still no stock I see.
I like the titan cooler. Best ref ever made.
I too got the evga 780ti sc Acx version last week but im returning it and buying the classified instead as long as it's in stock on the 06/12
With the classified being delayed until after Xmas, I've changed my order and gone with the Phantom instead. Have I made the right choice or should I have just picked a reference model and saved 50 quid? I've read good things about these Phantom coolers though. What sort of overclock should I be hoping for, should it push a bit further than a ref model?
The phantom cooler is very quiet, however every gainward / pallit card I've ever had or seen has been an awful clocker... I'd go with the gigabyte if wanting best overclocks, or save the money and get a ref model
+1 for Ref model of Gigabyte evga asus or MSI but I'm not sure about the inno3d iChill it might be a winner?
ACTUALLY I might just order two of these Inno3d 780ti as that would go with the rest of my system colours of balck and white :)
According to the review I read the Gigabyte doesn't over-clock very well at all...the EVGA SC ACX over-clocked better and gave better results. If you want the best factory oc then go gigabyte, if you intend on ocing it some more perhaps not.
