How's this look
Cheers for the reply, It will 100% be run at stock, my friend is not tech savvy enough for overclocking.
I think the OP's spec is probably better for the intended use. I'd take the Hassy i5 over a Piledriver for CAD/general desktop use any day.
I feel Intel will be better too (and i work with CAD programs).
Some (most) applications use a limited(rescrited) amount of cores and rely on the "power" per core the PC provides.
Our systems are 2 x 6-core xeons. At most the program we use uses 4-6 cores (not even 100% either).
CAD programs tend to be heavily single threaded and the Piledriver architecture suffers additionally by it's shared floating point scheduler between the cores. Rendering benefits from hyper-threading. With CAD programs I'm sure raw speed still rules over hyper-threading, so go with Intel IMHO.
