- 8 Aug 2012
Hey all, I'm having an issue with my system in that its overheating, even just when its sat in idle for about 20-30 minutes. I have a Corsair H100i Closed watercooling unit that just isn't dissipating the heat. Usually, for those of you that are familiar with the corsair solutions, I have the default fans that came with the H100i in PULL CONFIGURATION and I could typically leave the Corsair Link 2 software to run the 2 connected fans in Quiet mode, which, even under load would keep my system at about 60-65C, however, after I first noticed my system was very hot I set the fan profiles up to performance, which automatically set the 2 pull fans up to 100% usage and I saw no difference in temperatures at all. I haven't touched the RPM divider in the corsair link 2 software as honestly, I don't know exactly what that does and there is a small message in the software saying to leave it.
When I opened my system up and put my hand over the CPU block/pump, it was vibrating which lead me to believe that it was still pumping. but, I don't really know what the issue is here without full tearing my system apart and checking it for leaks. (I don't open up my system very often, is it all at all possible it may have leaked and then dried out?) What would somebody recommend I do? I''ve owned the unit since the end of April 2013 and i purchased it from amazon, so barely even a year, which is why I don't think it could be anything to do with the unit itself, there are no kinks or sharp bends in the hosing.
System Specs:
AMD Bulldozer FX-8150 8-core @3.6Ghz Overclocked to 3.8Ghz
Asus Crosshair formula V mobo
Asus Direct cu-2 7870 2Gb
Corsair 8Gb RAM @1600Mhz
Corsair H100i Cpu Closed water cooling unit with default fans in Pull Config.
Corsair Force GT 120Gb SSD
Corsair AX750w PSU
Corsair SP120mm fans down volted to 7v via small adapaters.
Corsair 600T Graphite case
Various harddrives.
(yes, I like Corsair)
Thanks for any help anyone can give me, I'm having to write this on my latop right now which is 5 years old and its painfully slow, I need to get my pc fixed again for my University work, my laptop can't handle large 3d modelling programs so i need a quick turnaround on fixing this.
System Specs:
Corsair AX750w PSU
Various harddrives.
