Are all modern graphics cards double thickness?
A quadro K4000 is single slot, though its cost is a bit excessive. Especially since it's gaming performance is probably on par with a 650ti. (768 cuda cores)
chaparral, how would i go about doing that for my Shuttle? is it a replacement "lid" for the case with a window pre-cut, or is that some kind of DIY mod?
It a DIY mod the owners have done themselfs..
Am guessing they most likely used a Dremel for cutting...
(Looks like you also need to cut out some the rear frame next to the PCI slot to make it a Double PCI slot)
