I'd expect it to be available for near the £1000 mark once the usual discounts off RRP happen, or at least within a few months after.
Still better value than taking the Korean panel gamble.
Not at 60Hz you can't.And 50" is far too large for a screen to be used as a monitor. Just ask Baddass how he'd feel about that as he stares at this 31.5" behemoth.
At this res won't this make reading text etc hard as it's going to be so tiny?
This, I currently use a 15.4" 1920x1200 laptop which has a slightly higher PPI but find it fine to use with no scaling.it is small, but actually not too bad once you've used it for a bit. you can always change DPI and text size if needed
ehehe, you know that fonts can scale right![]()
just received the UP3214Q for review. what a MASSIVE screen and resolution, even coming from a 27" 2560 x 1440 res! not sure how long it will take to get used to all this space
Any owners of this monitor experience problems while using it in 60hz?
