With a host of new firmware and fully licensed for Gran Turismo 6, the ultimate racing simulation peripheral has just stepped up a gear!
Not only that but we have the TH8 RS race shifter, TX Racing 458 Wheel for XBOX ONE & PC, Ferrari Legend for PC and PS3 as well as the brand new T80 Driveclub Wheel for PS3 and PS4.
STEERING WHEELS.
WE HAVE THEM.
Thrustmaster T500 RS Simulator Racing Wheel for PS3 & PC Licensed for Gran Turismo 6 @ £389.95 inc VAT
H.E.A.R.T. HALLEFFECT ACCURATE TECHNOLOGY™” is the name of the new technology developed by Thrustmaster to reproduce movements made on a product in games. It relies on magnetic – and not mechanical – 3D (HallEffect) sensors, placed in different locations according to the product in question. The precision made possible by the use of this technology is significantly higher than that provided by standard technologies. Another advantage of this system: by eliminating all friction, it guarantees zero mechanical wear, for permanent precision that won’t decrease over time. The level of precision is also enhanced by the absence of any dead zones: even the slightest movement made by the player results in a reaction. Actions in games are therefore more linear, smoother and without any untimely jolts.
- Authentic wheel: 30cm (12”) in diameter with brushed metal central spokes
- Authentic sequential gearshift levers: crafted of brushed metal, attached to the base (so they don’t move with the wheel)
- 17cm in height (for instant access along 1080°)
- Precision, Force Feedback & realistic angle of rotation
- New H.E.A.R.T Hall Effect AccuRate Technology™ on the wheel’s steering:
- Ultra-precise wheel, with 16-bit resolution (65536 values on the steering)!
- Precision that won’t decrease over time (contactless magnetic sensor)
- Force Feedback with industrial motor (Torque 150mNm, 3000rpm, 65W, Ø 52mm/2”)
- Super-powerful, quick responding Force Feedback mechanism
- Rigid motorized stopper, no matter what angle of rotation you select
- Mechanism with large dual belts (fluid and smooth action)
- Angle of rotation adjustable up to 1080° (3 full turns)!
- Realistic pedal set
- Unique design with your choice of 2 positions:
- Floor-mounted position (F1-style)
- Suspended position (GT-style)
- 100% metal, for optimal stability, weight (more than 7 kgs) and resistance
- 3 100% adjustable pedals (spacing between the pedals/height)
- Brake pedal with reinforced and adjustable resistance (included and removable “Realistic Brake” mod)
- Included metal footrest with non-slip grating texture
Was £399.95 Inc. VAT
Only £389.95 inc VAT.
ORDER NOW
Thrustmaster TH8 RS Shifter - PC @ £99.95 inc VAT
To meet the expectations of numerous motor racing fans, Thrustmaster is launching the TH8 RS, a high-end, separate and versatile gearbox. The device's two configurations, H-pattern and sequential, enable drivers to select their favorite driving style.
Realism and versatility:
Some virtual drivers cannot imagine shifting speeds otherwise than with a specific gearbox. With the TH8 RS, which boasts unrivalled technical innovations supported by pending patent applications, Thrustmaster now offers a device that is realistic enough to satisfy even the most demanding drivers.
At first glance, the TH8 RS looks realistic enough to be fitted to a real car. It features a 13 cm (5.12 in.) tall stick with a removable knob; the stick is compatible with real-life universal gear shift knobs. The TH8 RS includes two interchangeable shift plates, each suited to a specific configuration H-pattern (7 gears plus 1 reverse gear) and Sequential (pull the lever towards the + mark to gear up, and push it towards the mark to gear down).
Total adjustability:
To allow users to freely adjust the TH8 RS to their convenience, the position and the rotation angles of the shift plate and clamping system can be adjusted by 360 degrees. The removable clamping system, optimized for any type of support, is also open to customization: it is suited to both table tops and shelves (1 to 55 mm thick) and cockpits alike (built-in 'screw threads' are located under the TH8 RS). Gear strokes can also be adjusted (via a downloadable PC application and the device's internal memory), as well as the gear shift's resistance.
Cutting-edge materials and technologies:
The internal mechanism, the lever, the outer housing and the clamping system are 100% metal. This robust design significantly contributes to the extremely realistic in-game sensations delivered by the TH8 RS.
Thrustmaster has also taken care to grace the TH8 RS with unrivalled precision, by including H.E.A.R.T (Hall Effect AccuRate Technology) technology featuring magnetic sensor, without any potentiometer or tact switch and therefore, without contacts, for an unlimited product lifespan. In addition, the firmware can be upgraded to offer all foreseeable evolutions, assuring users that the TH8 RS is here to make a lasting impression.
The TH8 RS with USB connectivity is compatible with the T500 RS racing wheel on PlayStation®3 (a list of compatible games is available on the Thrustmaster support website) and with all currently available racing wheels for PC.
- Extreme realism:
- Shifting gears feels just like in a real car
- 13 cm tall gear stick with knob
- Detachable knob compatible with real universal knobs
- Ultimate versatility:
- Unique design enables 2 driving styles by using the two interchangeable shift plates provided:
- "H"-pattern (7+1)
- "Sequential (+/-)"
- Used with a PC, the gearbox is compatible with all racing wheels and games on the market that support multi-USB and gearboxes
- Used with the PS3, the gearbox is compatible with racing wheels (including the T500 RS) and games (**) that have been developed to be compatible.
- 100% metal internal mechanism, lever, and clamping system
- Absolute precision:
- H.E.A.R.T HallEffect AccuRate Technology
- Contactless magnetic sensor ensures consistency over time
- No "Tact switch" no potentiometer for unlimited product lifetime
- Full adjustability:
- Upgradable firmware and internal memory with adjustable gear-shift travel (downloadable software on PC)
- Adjustable resistance when changing gear
- Shift-plate position and rotation adjustable by 360°
- Clamping system position and rotation adjustable by 360°
- Optimal clamping (built-in screw threads + removable clamping system):
- Tables or shelves from 1-50 mm in thickness
- Cockpits
Only £99.95 inc VAT.
ORDER NOW
Thrustmaster TX Racing Wheel Ferrari 458 Italia Edition XBOX ONE & PC @ £349.99 inc VAT
Developed in close collaboration with Microsoft, this 7:10 scale replica of the emblematic Ferrari 458 Italia wheel is fully dedicated to Xbox One, including Binder ID and Xbox One Guide button. Designed for true racers, it features metal gas and brake pedals, and gear sequential paddle shifters. This new generation wheel will deliver unrivalled feelings in Forza Motorsport 5 and future racing games on Xbox one: Racing sensations at a level never seen before.
Features:-
- Developed in close collaboration with Microsoft, this 7:10 scale replica of the emblematic Ferrari 458 Italia wheel is fully dedicated to Xbox One, including Binder ID and Xbox One Guide button.
- Designed for true racing fans, it features metal gas and brake pedals, plus sequential paddle shifters.
- This next-generation wheel will deliver unrivalled feelings in Forza Motorsport 5 and future racing games on Xbox One: enjoy racing sensations at a level you've never experienced before.
Realistic: 28 cm in diameter, with textured rubber grip
2 large, wheel-mounted sequential paddle shifters
10 cm tall, and attached to the wheel
100% metal
Super high-end tact switch (lifespan of more than 10 million activations)
Comprehensive driving controls
10 action buttons (including 1 on the base) replicating the controls found on the real wheel
Replica 2-position Manettino® dial + replica ENGINE START D-Pad
Detachable wheel featuring Thrustmaster Quick Release system: quickly switch from one wheel to another
Only £349.99 inc VAT.
ORDER NOW
Thrustmaster Ferrari Racing Wheel Red Legend Edition PS3 & PC @ £59.99 inc VAT
The Thrustmaster Ferrari Racing Wheel is a product manufactured under the offical Ferrari license. The name with worldwide notoriety!, Ferrari is the emblem of victory and automotive compeition values that are genuinely appreciated by gamers.
100% compatible wheel in all racing games on PlayStation®3 and PC*
(GT, F1, NASCAR, Rally, GRID 2, etc.)
Wheel handles with Ferrari ®-like red rubber texture coating
Ferrari ® style on-wheel sequential digital gear shift levers
Features:-
- Large optimized pedal set
- 2 pedals with wide foot-rest
- Adjustable angle of inclination for each pedal
- Brake pedal featuring progressive resistance
- Fully programmable functions
- Fully programmable: 2 sequential levers + 11 action buttons + D-Pad.
- Large programmable, progressive pedal set with wide foot-rest for ultra-precise, comfortable - acceleration and braking.
- Adjustable wheel sensitivity for precise driving
- Linear resistance
- Auto-centring
- Thrustmaster ® "bungee cord" exclusive system providing with realistic resistance
- Central clamping system with wide jaws for optimal stability with all
- Desk and table types
Only £59.99 inc VAT.
ORDER NOW
Thrustmaster T80 Driveclub Edition Racing Wheel PS4 & PS3 @ £84.95 inc VAT
The T80 - DRIVECLUB Edition has been specially designed to help you beat your best times, for unrivaled performance. To achieve this, the wheel incorporates some major advantages, including its angle of rotation: this is much larger on a wheel compared to a gamepad’s mini-stick, allowing for a vastly greater level of precision on the steering axis. Other important advantages lie in the wheel’s large 25 cm diameter, and its ergonomic design providing perfect control with all types of cars – including rubber textured cladding on the wheel’s grip surfaces: this results in enhanced handling and ideal driving comfort, for smoother turns and better drifting. Sensations provided by the T80 - DRIVECLUB Edition are also incredibly lifelike, thanks to the wheel’s realistic linear resistance with automatic re-centering via Thrustmaster’s exclusive Bungee Cord technology.
The controls available on the T80 - DRIVECLUB Edition are also particularly comprehensive, including 11 action buttons, a multidirectional D-pad and wheel-mounted sequential paddle shifters (2 digital Up and Down shifters to let you shift gears more quickly!).
What’s more, the wheel’s central clamping system ensures total stability, even during intense gaming sessions. The large pedal set features adjustable angles of inclination for the pedals, allowing for optimized acceleration and braking according to the user’s preferred driving styles.
Features:
- PS4 / PS3 sliding switch (for full compatibility of the USB Racing Wheel on PS3
- Wheel grip with rubber texture coating
- 2 On-wheel sequential digital gear shift paddles
- Large optimized pedal set - Adjustable angle of inclination for each pedal & Brake pedal featuring progressive resistance
- Large programmable, progressive pedal set with wide foot-rest for ultra-precise, comfortable acceleration and braking
- Linear resistance - Auto-centering
- Central clamping system with wide jaws for optimal stability with all desk and table types
Only £84.95 inc VAT.
ORDER NOW
STEERING WHEELS.
WE HAVE THEM.
ORDER NOW
- Extreme realism:
- "H"-pattern (7+1)
- Cockpits
ORDER NOW
Features:-
100% metal
ORDER NOW
Features:-
- Linear resistance
- Auto-centring
ORDER NOW
Features:
ORDER NOW
