RIVE Black Edition and 3970X
Man of Honour
21 May 2012
Dalek flagship
Just found out my new RIVE BE is on the way and I want to use my 3970X in the board. When it comes to settings is the Black Edition much the same as the RIVE to use. I will also be using a set of the Dominator Platinums as well.
I have four 290Xs to run on it so I need to get the most out of the CPU.:D
Thanks.
Which Dom Plats are you going to use?
The C9 2400mhz 16gb (4 x 4gb) ones.
With SB-E they will do 9-11-11-25 1T 96 @2500mhz, I will probably be using my 3970X CPU but I also have a new 4930k which I may give a try. The 4930k should be interesting with the Dom Plats.:D
not exactly the same as the bios for r4be is a little bit of raw at this moment. R4E is the most stable x79 mobo from asus right now.
