I would chose the N5 so it's not lumbered with LG's terrible software.
Had both, like both
Hard to choose, if your used to running on latest android then go for the n5, now with 4.4.1 out it's become even better.
G2 is awesome but lg are very slow releasing updates.
if you plan on using custom ROM, then G2 no doubt.
N5 every time.
What is terrible about LG's software out of interest?
uhm, nope.
the only reason to choose N5 over G2 is pure Android. if OP plans to use custom ROMs anyway, there is absolutely NO reason to pick N5 over G2. It's a worse phone, with better software support from Google.
What software is the LG G2 ROMs missing that the Nexus 5 custom ROMs only have then?Better ROMs for the N5 as well. And as you may or may not know software is what makes a phone. 4.4.1 is a grand example.
uhm, nope.
