- 2 Jun 2012
Hello all,
Got a really frustrating problem with my new-ish laptop. It has a switch-able graphics setup, but I haven't been able to use it the entire time I've had the laptop. I've only just got round to needing this setup and having time to fix it.
If I tried to open CCC or the switch-able graphics options it would tell me something along the lines of "No options to configure" and nothing would ever happen apart from that. Since then I have tried a variety of things:
Reinstalling CCC over existing CCC - New CCC fails to install/repair
I then un-installed CCC from Add/remove programs.
- AMD Driver automatic setup - Downloads incorrect 'mobility' drivers that cannont install.
- 'Normal' AMD drivers - Refuse to install, get the following error message.
'Application Install: install package failure!''
I have also tried this after running Guru 3d Driver Sweeper in safe mode and get the same message. The log that is output with this is as follows:
<?xml version="1.0"?>
<?xml-stylesheet type="text/xsl" href="Report.xml.xsl"?>
<monetreport xmlns:dt="urn:schemas-microsoft-com:datatypes">
<general>
<cmdline>-UI </cmdline>
<time>12/08/13 19:43:06</time>
<action>install</action>
<download></download>
</general>
<dcm>
<primary>
<name>AMD Radeon Graphics Processor</name>
<manufacture>Advanced Micro Devices, Inc.</manufacture>
<chiptype></chiptype>
<chipid>0x6601</chipid>
<vendorid>0x1002</vendorid>
<ssid>0x05ba</ssid>
<ssvid>0x1028</ssvid>
<classcode>0x030000</classcode>
<revisionid>0x00</revisionid>
</primary>
</dcm>
<exist>
</exist>
<install>
<package>
<description>AMD Catalyst Install Manager</description>
<result>Fail</result>
<version>8.0.915.0</version>
<size>20 </size>
</package>
</install>
<uninstall>
</uninstall>
<downloaded>
</downloaded>
<resource>
<hwinfo>Hardware information</hwinfo>
<existpkg>Existing packages</existpkg>
<pkg2inst>Packages for install</pkg2inst>
<pkg2uninst>Packages for uninstall</pkg2uninst>
<otherdev>Other detected devices</otherdev>
<errmsg>Error messages</errmsg>
<name>Name</name>
<manufacture>Manufacturer</manufacture>
<chiptype>Chip type</chiptype>
<chipid>Device ID</chipid>
<otherhw>Other hardware</otherhw>
<download>Download packages</download>
<succeed>Success</succeed>
<fail>Fail</fail>
<vendorid>Vendor ID</vendorid>
<classcode>Class Code</classcode>
<revisionid>Revision ID</revisionid>
<ssid>Subsystem ID</ssid>
<ssvid>Subsystem vendor ID</ssvid>
<header1>Catalyst™ Install Manager</header1>
<header2>Installation Report</header2>
<finalstatus>Final Status:</finalstatus>
<versionofitem>Version of Item:</versionofitem>
<size>Size:</size>
<bytes>Mbytes</bytes>
</resource>
<error><msg>Application Install: install package failure!</msg></error></monetreport>
Here are the most relevant specs:
Intel Core i5 3427U
Intel HD Graphics 4000
AMD Radeon 8730m
Windows 8.1
I have a system restore point that takes me back to the broken version of CCC if needed.
I thought I could handle ordering a dell as I'm fairly good with computers - clearly not. Customer service is an absolute shambles and the product...well this thread speaks for itself. Arrived non-functional after waiting for it for far too long. At least it doesn't smell like cat **** (one of Dell's newer features).
Thanks for any help you have to offer.
<general>
</general>
<dcm>
<primary>
<ssid>0x05ba</ssid>
</primary>
</dcm>
<exist>
</exist>
<install>
<package>
<size>20 </size>
</package>
</install>
<uninstall>
</uninstall>
<downloaded>
</downloaded>
<resource>
<name>Name</name>
<fail>Fail</fail>
<size>Size:</size>
</resource>
Intel Core i5 3427U
AMD Radeon 8730m
Windows 8.1
