Need an experts opinion on this build
18 May 2009
Gloucester
Right, I'm done with huge cases full of nothing but air (non watercooler here) so I am looking at going the MATX route.
This is what I am thinking of:
http://www.overclockers.co.uk/viewcart.php
I already have a GTX Titan
Prolimatech Megahalem
OCZ Vertex 4 SSD
2 x WD RED 3 TB's
Seasonic X 850 Gold Haswell Compatible 160mm Length (emailed and checked)
Does it seem like a sensible rig?
Thanks in advance
Chris
YOUR BASKET
1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - OEM £169.99
1 x ASRock Z87M OC FORMULA Intel Z87 (Socket 1150) DDR3 Micro ATX Motherboard £139.99
1 x Silverstone SST-SG10B Sugo SG10 USB3.0 - Black £109.94
Total : £429.53 (includes shipping : £8.00).
OCZ Vertex 4 SSD
2 x WD RED 3 TB's
Thanks in advance
Chris
Fair does..
I think the case is a good choice (though I don't find it pretty) it is excellent at cooling.
Obvoiusly the CPU is a good choice.
Personally id splash the cash on a gene or a sniper. Much better than the Asrock.
Cheers for the reply. Will check out the sniper and gene. Just wanted something tidy to keep on my desk. I guess the case is an acquired taste but my only other likes were the prodigy and the phenom but my cousin has one and even with a 160mm modular psu it was a real pain so he switched to a 150mm and it made the case so much easier. Unfortunately I don't have the budget to replace the psu as well. Shame as I do like the look of the prodigy and phenom. I haven't ruled out mini itx yet either and I do like the horizontal MB layout of the mini itx on the prodigy
At 3.00pm this afternoon I was sure of what bits I wanted and I was a click away from buy now but just not so sure now what to get. I do like the SG10 and the Bitfenix range, I have been looking at the Aerocool DS as well but I would prefer to get all my bits from OCUK.
Just noticed this:
YOUR BASKET
1 x Xigmatek Aquila Micro-ATX Case - White Window £74.99
Total : £84.59 (includes shipping : £8.00).
I like the look of that!
Wow!
Im not sure im 100% on the style but its certainly a very good case..
The layout is like a prodigy (ITX) but made mATX (the Prodigy M is different).
Its a good choice..
Though personally (i've not owned a case by this manufacturer so i can't comment on their build quality..) id go for the silverstone/Lian Li as ive owned cases by both and their build quality is second to none (apart from each other...)
