Sapphire Radeon R9 270X Boost OC 2048MB GDDR5 PCI-Express Card with BattleField 4 PC Game Included @ £149.99 inc VAT
The "dual" in Dual-X refers to the two highly advanced cooling fans that are coupled with multi-heatpipe technology to cool mid-to high-end graphics cards. The fans are amazing: each blade boasts a sleek airfoil shape that increases cool air throughput so they can run slower. Even when you're pushing the processing power to the limits. Even when your're overclocking.
The quiet-running fans work with multi-heatpipes and heatsinks that take away heat from the processor to the fans. Plus, dust repelling bearings radically reduce failure caused by the build-up of dirt. In short, its a quiet, efficient way of cooling your graphics card - even when you're pushing it to the limits.
Specification:-
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- Hugely overclockable
- Core Clock Speed: 1020MHz
- Core Boost Speed: 1070MHz
- Shader Architecture: GCN
- Stream Processors: 1280
- Frame Buffer / Memory: 2GB GDDR5
- Memory Width / Speed: 256 bit / 5600MHz
- Power Connectors: 6-pin + 6-pin
- Display Outputs: 2x DVI + 1x DP + 1x HDMI
- Power: 180W TDP
- 2yr Warranty
Only £149.99 inc VAT.
ORDER NOW
____
Samsung S27B970D 27" Widescreen Ultra Thin LED Professional PLS Monitor - Black @ £499.99 inc VAT
The trailblazing big-screen Samsung Series 9 introduces an exceptional generation of monitors, with superior visual advances from the industry’s five-year global market leader. Remarkable resolution and vivid brightness fill the screen edge to edge with the limitless colors of nature, delivering unrivaled picture quality. Set on an elegant base with a sleek frame, the monitor renders intensely rich colors and astonishing detail, even at wide angles. Quite simply, the Series 9 outshines other screens.
Samsung’s exclusive technology automatically calibrates brilliant true-life color, taking the challenge out of choosing a monitor with premium picture quality. The Series 9 relives your memorable moments on the monitor in the vivid detail you remember.
Answering the need for higher resolution and precise detail editing, the Series 9 Monitor showcases extraordinary picture quality without losing any color or perspective, even from ultra-wide angles. Its WQHD technology enables the images to remain ultra-crisp with resolution that’s four times
higher than older conventional HD monitors.
With its slim and gleaming silhouette, the Samsung Series 9 showcases shimmering images that seem to display in mid-air. The crystal clear tempered glass screen enhances both the vivid images and the streamlined design. Innovative LED Touch UI delivers emotionally intimate engagement and satisfying results. Ports are artfully concealed in the back to highlight the stylish brushed aluminum hairline (HL) finish. Simply elegant, the Samsung Series 9 Monitor represents world-class innovation.
Defined by distinctive forward-looking and consumer-friendly design, the Samsung Series 9 Monitor is made for ongoing value. The Series 9 internal performance is as advanced as its striking exterior. Along with sensational good locks, you’ll discover intuitive and exacting technology as well as an ergonomic Height Adjustment Stand (HAS) and tilt for comfortably customized viewing. The Samsung Series 9 offers unequaled simplicity.
Engineered to deliver unparalleled picture quality and consistently accurate all-natural color, the Samsung Series 9 works to make that experience as seamless as possible. Enjoy content from MHL-enabled smartphones and tablets with the benefit of richly displayed images and compelling audio. You also can simultaneously browse on smartphones and even charge devices.
The Samsung Series 9 premium monitor delivers the best in picture quality, style and connectivity. Its exclusive color technology renders vivid content, video, photos and more. This monitor sets the new standard for sophisticated and approachable design, appropriate for any décor. Multimedia connections are easy and seamless for all devices. The Samsung Series 9 will surpass your every expectation.
Specification:-
- Screen finish: Glossy (Reflective)
- Screen Size: 27" / 68cm (16:9)
- Type: PLS LED
- Brightness: 285cd/m (High Bright Mode), 220cd/m (Standard Mode)
- Contrast Ratio: Mega DCR (Static 1000:1)
- Resolution: 2560x1440 (Wide Quad-HD)
- Response Time: 5ms
- Viewing Angle: 178 / 178
- H/W Calibration Engine
- Connections: Dual Link DVI, DisplayPort, HDMI 1.4
- 2x7W Speakers
- USB Hub
- Dimensions: 645 x 467 x 247mm
- Warranty: 3yr
- Product Review: http://www.expertreviews.co.uk/monitors/1293385/samsung-series-9-s27b970d
- Product Videos: http://www.youtube.com/samsungmonitorglobal; http://www.youtube.com/watch?v=Pn3gsyEKzKQ&noredirect=1
Only £499.99 inc VAT.
ORDER NOW
Specification:-
- Power: 180W TDP
- 2yr Warranty
ORDER NOW
____
Specification:-
- Type: PLS LED
- 2x7W Speakers
- USB Hub
- Warranty: 3yr
ORDER NOW
