Asus 7970 DCuII Top - OC
27 Nov 2012
Wales
Hi,
Im tryind OC my GPU, but im limitted with MHz and vCore on ASUS GPU Tweak.
How I can go for higher vcore and MHz on my GPU?
uninstall asus gpu tweak and install the latest beta version of msi afterburner! worked for me.
Unfortunately not working to me. I installed latest version of MSI afterburner (beta) and its still locked.
Hi,
Your card is voltage locked. You can flash it with the 7970 Matrix bios to unlock the voltage.
I did this with mine, it works brilliantly.
that's cool.
Have you got any step-by-step guide how flash properly this card.
I'm not best with flashing but still learning :)
Im apologize for my english. I hope you understand.
Thanks for all answers.
that's cool.
you need a program called ati winflash and the bios, you can get both of these from techpowerup.com
there is a guy on here called Rob his user name is 233 - he very kindly emailed my all the stuff I needed including the bios but I cant find the email now. Maybe you could send him a message in trust im sure he would be happy to help.
My thread where is all cam together is here http://forums.overclockers.co.uk/showthread.php?t=18558946
This is the link for winflash http://www.techpowerup.com/downloads/1919/ati-winflash-2-0-1-13/
this is a tutorial of how to use it http://www.overclock.net/t/1353325/tutorial-atiwinflash-how-to-flash-the-bios-of-your-ati-cards
and I think this is the correct bios http://www.techpowerup.com/vgabios/130348/asus-hd7970-3072-120813-4.html
HOWEVER IM NOT 100% SURE IF THIS IS THE BIOS I USED IT IS FOR THE 7970 MATRIX non platinum version.
PLEASE DOUBLE CHECK THIS WITH THE COMMUNITY I WONT TAKE ANY RESPONSIBILITY IF YOU BREAK YOUR CARD.
Good luck :)
/pulls mace out of man bag and backs away slowly :D
How's your card going nick?
My top is sitting quite happy at 1300/1750 albeit even with the direct cu II cooler it's still doing its best impression of a jet fighter when I ramp it up
Adjusted the fan profile to keep it under 70 at full chat
Flashing your card is scary but it can pay off big time (never bricked a card doing this). My advice to you is research, double check, tripple check and go slow.
Dude i sold it on the MM and bought two 780Ti lmao but it was sweet to use for the short while i had it :D
I have the same question regarding my amd hd 7970,I can't increase voltage??I'm using msi afterburner 2.3.1. Did amd locked this card later in production cycle?
Bios flash is the only option for me??
asic on the card is 82,9%
So far on stock voltage I got 1000mhz core and 1500mhz memory.Passed test in Sleeping Dogs on highest preset.Can I consider this stable then?
