Are you a Psychopath?
21%
You are warm and empathic with a heightened awareness of social responsibility and a strong sense of conscience. You like to carefully weigh up the pros and cons of a situation before you act and are generally averse to taking risks. You are very much a ‘people person’ and dislike conflict. ‘Do unto others…’ are your watchwords. But, although you avoid hurting others, those residing at the higher end of the psychopathic spectrum might not be as considerate, so stay vigilant to avoid being hurt unnecessarily
Same. I don't think I'm a 'people person' but I am a very strong believer of the 'Do unto others' part.
30%
You are warm and empathic with a heightened awareness of social responsibility and a strong sense of conscience. You like to carefully weigh up the pros and cons of a situation before you act and are generally averse to taking risks. You are very much a ‘people person’ and dislike conflict. ‘Do unto others…’ are your watchwords. But, although you avoid hurting others, those residing at the higher end of the psychopathic spectrum might not be as considerate, so stay vigilant to avoid being hurt unnecessarily.
I agree with the first half, i completely disagree with avoiding conflict, i like a good argument. I agree with 'do unto others' but don't live by it wholeheartedly.
Then again it's along the same lines of a horoscope, a load of stuff that is supposed to apply to the masses, which is never going to be accurate.
Your score - 55%
Though your conscience is in the right place you also have a pragmatic streak and generally aren’t afraid to do your own dirty work! You’re no shrinking violet - but no daredevil either. You generally have little trouble seeing things from another person’s perspective but, at the same time, are no pushover. ‘Everything in moderation – including moderation’ might sum up your approach to life.
58%
YOUR
SCORE 30%
Your
score 21%
meh boring and also incorrect. Certainly not a people person and I always end up in conflict even when trying to avoid it :p
36%
