Flexible PCI-E X4 pci-e riser card extender ribbon cable
11 Dec 2012
Bangor - Northern Ireland
Hey all im looking the following
I have fould lots of places selling them, however max length is only 10-15cm. For my purpose i need around 30cm.
Can anyone point me in the direction of getting one of this length. Or advised if i connected 2 15cm ones together.
Its for extending to a PCIe SSD. due to graphics card locatation(3slot) the x4 pcie is covered.
Thanks
I would have thought you could just put two together.
Quite possible. PCIe is very sensitive to timings though, which is partly why available cables are usually quite short. I'd thoroughly test this interface before putting any faith in it, even then backups are very wise in any case
well im changing from an antec 1100 case to an 810 switch, which is currently in transport.
ill do some testing at weekend.
its the sexy ROG RAIDR Express SSd. Was wanting a long cable so i can have it as a nice feature in the sidepanel window with a customer bracket :)
i will find a way round it. i can get a 30cm x1 adaptor, but i want the x4 to not effect the transfer speeds
