- 1 Jun 2012
- UK
Gah so my pc is on all day, and has been since i last changed hardware/cleaned it and i comeback to day and my dad has decided to turn it off...... AT THE *** **** ******* PLUG i mean seriously you own a pc and you cant be bothered to shut it down???????
Anyway because of this chrome has updated and now for some reason when i put a youtube video to full screen and click on my other monitor it exits full screen. Never had this problem before and the only way to stop it is disable part of flash....which then means adblocker stops working. Does anyone know how to fix this or has had this problem cause it is really frustrating, i like to watch youtube while i game and now i cant (well with ads which are usually 10x louder than the video ear raping me)
Edit: also for you electricians, is there anyway to disable the switch on the wall so that it is on constantly, i ahve the glue to glue the plugs to the socket all i need is to disable the switch on the plugs sockets and then i can disable the power button in windows then sorted
