Off to buy a Land Rover Discovery 3 tomorrow
looks good. SE/HSE trim?
I presume it is the 2.7 TD opposed to the 4.4 V8 Petrol?
What miles had it done in the end? just over 105?
5 or 7 seater?
HSE trim 2.7td and 7 seater :)
It was on 108000' was motd and serviced 100 miles previous
Go on then, what's the "tiny issue" :D
Nice colour. :cool:
The issue is that when it's really cold the auto box can take an age to engage first gear. Now if I switch the manual it's instant, and if I go to reverse its instant. It apparently can be a tiny cog which is a simple £3 part and easy fit, can also be needing a gearbox reset.
We shall see
Congrats on a great looking car, you'll love it! I was looking round for months for one but the GF went and spent my money elsewhere, hoping to get one next year now! Disco3.co.uk is a great site, and lots of work on them can be done yourself with the right tools, people say they cost a lot to maintain but they seem ok from what I've read. My focus is costing more than a Discovery would have! Enjoy! :)
We shall see
£3 part which requires the body off to fit :D
Lovely disco btw. I love them. Going to be interested in what the replacement looks like.
Just put the deposit down on one of these myself (HSE like this but V8 Petrol), I'm due to collect on Sunday 12th, so pictures and details to follow :)
I'll expand on that a bit.
I managed to get the V8 for significantly (4 figure sum that starts with a 3) less than a diesel in comparable condition. There isn't a lot of demand for the V8 petrol because everyone goes 'GOOD LORD THE FUEL BILLS'. This in itself buys a lot of fuel.
Then factor into calculations....
- The diesel really doesn't exactly excel in the economy stakes. Real world calculated figures (not on the dash computer) see the diesel averaging low 20's combined.
- The fact that for the age vehicle I'd be buying the diesel will be getting close to the usual EGR/Injector/Turbo woes
- Diesel costs more than petrol
- The diesel uses a belt that costs a fortune to change and the petrol has a chain drive....
- The diesel seems to have a habit of causing gearbox problems, I couldn't find a single petrol that had this issue.
- The petrol and diesel of this age have the same road tax cost.
- The petrol drives a lot nicer. There isn't a price for this, but the noise, performance and refinement are worth
I did do a proper spreadsheet, but I don't have it to hand. I think you need to cover serious (something close to 50,000) fault free miles in the diesel for it to cost less than the petrol. By which point, you might be needing to change that cam belt again and it all goes to the petrol again.
Sure you can do some mitigation and get the EGR blanked off, but that in itself isn't free and that eats into running costs.
Everyone has a reason for why they will have picked a diesel, and it is probably down to availability of the petrol or a preference of a diesel.
Everyone has their choice, and I have always fancied owning a V8. Sure it isn't in a sport chassis, but I really enjoyed the drive. It had enough go to make the Discovery even feel... brisk .. whereas the diesel just seemed a bit exhausted. I'm told a remap does wonders though.
All of the above is written with a bit of man maths thrown in, but seriously, there wasn't much in it.
The only reason I chose a diesel is I fully intended to dunk it up to it's door handles in water from the moment I got it, otherwise I would have also gone V8
As Conanius says, there is very little difference in MPG between the two (got work mates with the V8 and know mine well enough to say they both hover around the 20mpg mark.
(18-20 for the V8, 20-22 for the Td5)
Jonny - It's one of yours I believe. 4.4 litre AJ-V8 that is a bored out version of the 4.2 used in the XK8.
I'd imagine it uses some different cams and map to the XK, but it made a lovely sound and was really smooth in its delivery :)
