Are you a Psychopath?
Your
score 24%
You are warm and empathic with a heightened awareness of social responsibility and a strong sense of conscience. You like to carefully weigh up the pros and cons of a situation before you act and are generally averse to taking risks. You are very much a ‘people person’ and dislike conflict. ‘Do unto others…’ are your watchwords. But, although you avoid hurting others, those residing at the higher end of the psychopathic spectrum might not be as considerate, so stay vigilant to avoid being hurt unnecessarily.
I would say a good 70% of the above is wrong.
Your
score 39%
Though your conscience is in the right place you also have a pragmatic streak and generally aren’t afraid to do your own dirty work! You’re no shrinking violet - but no daredevil either. You generally have little trouble seeing things from another person’s perspective but, at the same time, are no pushover. ‘Everything in moderation – including moderation’ might sum up your approach to life.
mrk! Dammit!
YOUR
SCORE 39%
See some other people have got that too, not an extremely in depth test but hey guess that's the point of it :)
EDIT: According to the site, the vast majority of Psychopaths listen to rap and read the daily star.... Interesting demographic :P
YOUR
SCORE 24%
YOUR SCORE 45%
I think that's a pretty accurate description of me.
On a side note my wife once got me to take an autism test so I'm not sure how others would describe me!!
70%
You can play hardball with the best of them! You know what you want and are not afraid to go for it – even if it means bending the rules occasionally and putting a few noses out of joint on the way. Nothing fazes you. You are decisive, self-confident and pretty much up for anything. You are a ‘means-to-an-end’ person. For you, it’s not necessarily a matter of right or wrong, but of what gets the job done. ‘Bring it on’ is your mantra, but to help those around you keep their heads, you should learn some tricks to help you temper your self-satisfying tendencies...
Although I disagree, as I have excellent empathy. Proper understanding of others emotional response, and how to manipulate/modify it.
I got 94%, but my mate is a psychiatrist and basically already told me I fit the profile of a psychopath (or sociopath? I can't remember). Doesn't mean you're an axe murderer. Most successful people are. :)
SCORE 70%
