I don't feel comfortable doing that and for the controller to be broken after probably 6 hours usage is a bit crap on the quality front.
I have emailed the guy mentioned above.
Ok I just tried to fix my ds4 r1 sticking. Pretty easy to fix but my trigger poped off.
So after I put it all back together. I started to notice not a lot of resistance in the right trigger.
Opened it up again to check and noticed that there was a tiny little spring missing....
Spent an hour with a torch trying to find it in the carpet with no luck. Was bout to give up and spotted that it somehow got stuck to the side of my chair.
So be careful if you decide to try and fix yours
It seemed to be left over residue from the manufacturing. I would tend to agree but dint want to be messing about with returns and all that jaz around xmas
packing my old ps3 up last night, went to use the ds3 to format the wipe the system as its sold, boy the ds3 felt offensive after using the ds4. The ds4 is just miles ahead in comfort its so untrue... impressive gamepad the ds4. I now prefer it over the 360 pad, and I did like my 360 pad over on the pc..
How did you pop It off did you have to dismantle the controller or just prise something under it? Can you also put it back on without dismantling it? Lastly residue? I thought it was catching on the body of the controller.. Hmm not sure whether to send mine back or not it sounds a mass problem so a replacement would be the
Edit emailed the above fella, also emailed gamestop it's not acceptable
Had to take the back off and unhook the ribbon.
Then you can push the r1/l1 out with a screw driver. The triggers are the really the only thing to watch out for when taking the back off.
The white stuff was hard to see. Am not sure if it's enough to cause the problem but I just wiped round there with a cloth on the tip of the screw driver. It's not sticking anymore.
It would be very hard for anyone to know if you had opened it IMHO as I never saw any stickers or seals
I like the new Playstation app but it turns my PS4 on everytime I use it! I've added 3 people from here to my friends list tonight and everytime my PS4 turned on![]()
http://m.youtube.com/watch?v=fRu3qKcUECk&desktop_uri=/watch?v%
YouTube to video of fixing the L1 without dissembling the whole
Also just recieved an email from that PS support address asking for my telephone number to call me regarding it.
