Where can I get one of these in the UK?
What i normally do if the case has a 3 pin spacing plug and a motherboard only has a 2 pin header is move one of the wires in the plug so that they are the correct spacing. It takes seconds and saves faffing around with adaptors.
^^ This, or split the connector with a sharp knife or cutters.
+1 takes seconds.
sometimes its the speaker or power cable.
Thanks, ill give that a shot! :)
