How do there,
Rightey, used to have a CoolerMaster HAF-X case and downsized to a Corsair 300R, that's basically just got the stock arrangement of fans (1 front, 1 top back), the HAF-X had good cooling, this doesn't, well doesn't currently, also much noisier...
Not a problem, HAF-X was ridiculously big and since I'm nearing 30...well, don't really want something like that knocking around anymore...However, have just got a couple of 780 Ti graphics cards, so need some airflow.
The available fan placements on the 300R are as follows....
2 x 120mm front fans
1 x 120mm back top fan
2 x 140mm top fans
2 x 120mm side fans
I would appreciate some advice on which fans to go for pretty please
If it's any help the 780 Ti graphics cards are of the blower variety (decided this on purpose as SLI is a joke in terms of heat unless you have a fantastic airflow which I know I'll never get).
I have a noctua tower cooler with the fans pointing upwards.
Please help, thanks for any recommendations and advice. I'm not after super cooling at the expense of noise, I'm also not after absolute silence. One other thing is that the side fan mounts on this case don't seem to be dampened very well so maybe I will need some rubber damper grommity things or something
Thanks again,
2 x 140mm top fans
2 x 120mm side fans
Thanks again,
