***The Official Battlefield 4 Thread***
I assume so, I was playing online till 3am this morning, turned on the ps4 a while ago and got a 1.52 update for the ps4 and the patch for BF4.
Just searched for patch notes.
The ability to pause and prioritise downloads.
Notifications when friends come online.
Incognito mode for when you just want that solo session.
YouTube uploads.
YouTube app.
Some sort of organisation/folders on the XMB for your library.
Themes.
Ooooh. :)
YouTube uploads.
YouTube app.
Themes.
Ooooh. :)
I've done 1.52 and whilst downloading the BF4 patch now there is no option to pause it.
Does anyone have a problem joining multiplayer on the xbox one??
I can't join any game game since yesterday I keep getting a error " you have lost the connection to the session". :confused:
"you"
No EA, no, you have screwed up server side..as per usual.
Decided to buy this now theyve issued another patch today for the PS4 - hopefully this one fixes most of the crashes and corrupt campaign saves...
ps3ud0 :cool:
voila:
Dec 11 PS4 Game Update Notes
-General stability fixes that should remove a large amount of the client crashes we are currently seeing on the PS4
-Fixed the audio drop outs that could occur when playing on large maps. Typical map affected was Golmud Railway in Conquest with 64 players. Ambient sound would sometimes cut out, like foley sounds from player running, vehicle engine sounds, vehicle movement sounds, and map ambient sounds
-Removed the blur effect on soldiers that appeared when Commanders were using EMP attacks
-Further reduced the probability of getting a corrupt save file by doing miscellaneous changes to the save file system. These include removing the save file saving again when quitting multiplayer
-Fixed multiple crashes that could occur when bringing up the in-game Battlelog during round transition
-Fixed a crash that could occur when using the BattleScreen
-Fixed a random crash related to destroying vehicles
-Fixed minor destruction issues in the terrain
voila:
Sexy!
I played the game just after the update with no problems. But then on the loading screen for the next game nothing was happening at all so I went to the XMB and closed the game. It messed up sound for my PS4 and I had to power down and back on to fix it!
The only way I could get into a game now was to log into Battlekack, and click on a server from it, which led to a game that was buggy as heel, my character kept like jumping/ croucing on his own, then I fell through the map.
countless counter measures on the little bird and none of them stopped on incoking missile.
