A cable to give your motherboard more usb headers?
4 Jan 2013
Hey, I have ordered a new power supply from corsair, and I know that it will need to be plugged into a usb header on my MOBO so it can be controlled by corsair link, the issue is that I have used all 4 I have, is there some sort of spliter to split 1 hub into two?
Are you sure you are not confusing USB header with Sata header?
I have never had to use more than one USB 2 header ever.
There's a direct connection to the USB header on the "digital" power supplies (same with the h100i AIO coolers)
Doesn't do a great deal apart from monitoring power usage, fan speed control etc..
I'm fairly sure he's correct with that, the PSU has a mini-usb slot that leads to a USB slot on the motherboard.
I know it does, but that was not my question.
I was just trying to make sure the OP was`nt confusing his ports with each other. As I said, I have never needed to use more than one USB 2 port.
