- 21 Jun 2011
Hello wise car-knowing forum folks.
I'm here looking for some buyer's advice (which I'm sure you get a lot).
My current car is an 05 plate Ford Ka super-basic jobbie. Picked it up for £500 off ebay when I was very skint a couple of years ago.
Obviously, buying a car that cheap and from ebay, I didn't have high expectations of it lasting forever, but in the last month or so I've had to replace the clutch, and a wheel bearing, plus the idle valve. Today it's gone in and needs the MAP sensor and one other sensor replacing (had a crazy random idle speed that was causing throttle surges - not the safest thing so I've just had to sack up and pay for it). This makes about a grand in repairs in the last month, and I'm fed up with it.
I'm going to try and part exchange it and get something similarly cheap, but younger and more reliable. Basically I'm looking for something to get me to and from work, to and from the gym and occasionally go on longer trips (e.g. take it on holiday to Cornwall etc).
What I liked:
Economic (fuel-wise), park it anywhere, cheapish tax, cheapish insurance, good enough acceleration to join motorways/dual carriageways without terror. I fit in it and can drive it comfortably (I'm 6'2" which is not THAT tall, but a surprising number of cars put my eyeline above the top of the windscreen, or when you run the seat back have the door pillar in the front half of your sight line etc)
What I didn't like:
It's a tin shell, and therefore it gets loud fast at non-town speeds.
No comforts at all. Manual windows, manual locks, scrape the windscreen (inside and out) if it's cold.
I managed to spin it once on a motorway slip road - full 360. The Mrs won't forget it.
It done broke.
What I wasn't that bothered about:
Top speed - I'm not racing it. As long as I can maintain **70** cough cough on a motorway it's fine.
It's a girl's/hairdresser's car - as mentioned, I'm 6'2" and I fit in it just fine. A lot of people seem to think it's worth pointing out a man my size getting in a Ka but I'm on the "amused" rather than "embarassed" side of that one, so not really bothered. Street cred/macho points very low on the list.
So - let's say I've got a budget of ~£1500 after part exchange. What should I be looking for?
What I liked:
What I didn't like:
It done broke.
