Hi there,
SupremeFX is something that we're always developing on our ROG boards, glad to hear you're impressed. I've included some information on the technology below:
1. Built-in SupremeFX IMPACT audio solution for the delivery of an unbelievable hearing experience with the humble HD Audio Device, featuring:
SupremeFX Shielding Technology, consisting of the following key elements:
- PCB Shielding, where each part of SupremeFX IMPACT has been carefully arranged to avoid unnecessary reduction of audio quality due to crosstalk or electric coupling for the optimal audio quality.
- Stainless Steel Cover, where the core of SupremeFX IMPACT is covered up by a stainless steel cover that blocks all electromagnetic interference Generated from nearby components from affecting the functionality of the audio core, allowing the SupremeFX IMPACT to perform at its full capability.
- The SupremeFX IMPACT audio module is moved out of the motherboard, enabling more layout space, as well as effective prevention of ground noise coming from the motherboard for the delivery of the top notch quality audio solution to the tiny mini-ITX platform.
ELNA® Premium Audio Capacitors are used to enable smoother change in capacitor charge and discharge for the delivery of a warmer and pleasant audio output.
High Fidelity OPAMP are adopted to form two separate differential output design as opposed to the traditional single-ended design to reduce the interference coming from the surrounding such as power noise. This enables a noticeably cleaner output, as well as better resolution for more details in the audio content it plays back.
Ti LM4562 Hi-Fi OPAMP is adopted at the front to high fidelity trigger headphone up to 600Ω, while delivering high resolution, excellent sound details as well as boosting the already heat-pumping effect fir extreme gaming reality.
Music PnP is newly introduced to transform the front MIC-In port into the input of any external audio devices when the system has been turned off. Enabling a clean yet easy to assess sharing of audio systems in your living room.
The inclusion of DTS™ Connect enables real-time audio encoding to allow multichannel digital audio output via the onboard S/PDIF port.
