So I just got a new cpu, and decided for now to wait a while before I enter the watercooling world. As such i wanted to see what my cpu was made of with everything stock just to see if there's nothing wrong.
So I ran Prime95 on the standard setting (not the one that generates extra heat) set my system to high performance (idle temps go from 30 to 40C) and then engaged the torture test. to my shock the temperature goes up to 96C. with the cpu fan at 100%.
The heatsink is seated properly, so that's not the problem, the side of my case is open as I'm measuring for future watercooling parts and where to possibly put them.
But really is the intel cooler that bad, that it can't even cool decently on stock? I wasn't expecting much, more around 85C at most, but 96-98C makes me worry.
Now I've been told that as long as it doesn't throttle that this is fine!? What is this throttling based on anyway, which temperature does it take? I've come accros 3 different temperatures for my cpu, AI suite from asus reports 69C while hardware monitor reports 84C under the motherboard section for cpu, and it reports 96C when looking at the cpu section. On what temperature would the throttling be based? If it's based on the 69C for the motherboard it won't throttle ever. and there's a 27C delta between that value and the cpu.
Even idling those temperatures can't seem to agree, in balance power mode it reports 26C (AI Suite), 28C (motheboard cpu temp), 32C (cpu temp).
