I had a new bathroom built end of last year. Around the clear silicone at the bottom of the shower screen there's a small formation of mould. Also, there's some behind the plastic wedges that support triangular glass corner shelves. There's 2 shelves above each other, and each shelf has 3 plastic wedges. Two wedges screw into the fixed glass part of the screen and one wedge screws into the tile. Each tile wedge has got some black mould behind, but the wedges attached to the fixed screen are fine. I was thinking of using domestos to clean it up, apparently it works as well as any mould remover?
I have a low voltage humidistat fan above the shower which comes on automatically each shower I take and stays on for as long as it takes for the humidity to lower. I have the window open when I shower. I wipe down the whole bathroom every day after each shower, takes about 15 minutes. Is there something else I should be doing? Or is this to be expected? It's a small bathroom, about 6' x 5' so moisture hits everything easily. The rest of the bathroom is still brand new looking and mould free. And that's the way I want to keep it! Now that I think of it, I do remember pulling some excess sealant away from around the post a few months ago, to try and push the shower screen seal further up. Maybe it broke the seal of the silicone?
This is my fan btw. Is it good enough or do I need a better one? Extract performance seems on par with others I've seen which are more costly.
http://www.ebay.co.uk/itm/12V-Bathr...D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
