** NEW IIYAMA MONITORS & SPECIAL CHRISTMAS IIYAMA DEALS!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
OK we have some great new monitors from iiyama and some special deals for Christmas, check them out here:-
IIyama Prolite E2273HDS 22" Widescreen LED Monitor - Black @ £115.99 inc VAT
The ProLite E2273HDS is a LED-backlit monitor. It is a full 1920x1080 high definition 22” display that features all the benefits this technology affords. Extremely slim and stylish in design, it has a narrow bezel and is finished in the latest glossy-black. The high specifications of the monitor include 5,000,000:1 ACR, fast 2ms response for excellent sharpness in high definition video and triple input connectivity (including HDMI). Power consumption is only 21W typical usage and 0,5W in standby.
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product.
With true 1920 x 1080p resolution your LCD is ready to display any high definition images. It also offers you much more viewable area than a standard LCD with 1280 x 1024 resolution.
Contrast Ratio is a measurement of this difference between the blackest black and the whitest white your LCD can display. Advanced Contrast Ratio is a feature that automatically adjusts the contrast and brightness based on the darkness of the image. The higher the ratio, the better your screen will look when you have the lights off in a room.
This LED monitor is equipped with two high quality stereo speakers. HDMI stands for High-Definition Multimedia Interface. Much smaller and more convenient than DVI, HDMI also has the significant advantage over DVI that it supports audio as well as video signals. When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
Features:-
- LED Backlit
- Screen Size: 22" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 5000000:1
- Brightness: 300cd/m²
- Response Time: 2ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1 x Analogue, 1 x DVD-D, & 1 x HDMI
- Dimensions: 268.1 x 476.6 mm; 10.6" x 18.8"
- Weight: 2.9kg
- Warranty: 3 Years On-Site
Was [£119.99] Inc. VAT
Only £115.99 inc VAT.
ORDER NOW
Iiyama ProLite E2278HD 22" Widescreen LED Monitor - Black @ £99.95 inc VAT
The ProLite E2278HD is a 21,5’’ FHD 1920x1080 LED-backlit monitor. It features 5msec response time and >5M: 1 Advanced Contrast Ratio assuring vibrant images and blur free Video. Analogue VGA and Digital DVI inputs ensure compatibility with the latest systems and associated graphics cards. The monitor is Energy Star qualified and VESA mount compatible. A reliable solution for both home and office use.
With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor.
Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games. VESA mount compliance means you can easily mount your monitor to a wall.
Features:-
- LED Backlit
- Screen Size: 21.5" Widescreen
- Response Time: 5ms
- Weight: 2.9kg
- VESA mounting: 100 x 100 mm
Was [£107.99] Inc. VAT
Only £99.95 inc VAT.
ORDER NOW
Iiyama Prolite X2380HS-B1 23" Widescreen LED Monitor - Black @ £129.95 inc VAT
ProLite X2380HS is a 23” LED backlit LCD Screen featuring IPS Panel technology which is considered to be the best all round panel type. It offers accurate and consistent colour reproduction with wide viewing angles (178°/178°) and great response time (5 ms black-to-black). The ProLite X2380HS is full HD, has a >5mln:1 Advanced Contrast Ratio and 250 cd/m² brightness offering the user a clear and vivid image. An array of inputs including HDMI, DVI and VGA connections ensure compatibility across a range of devices including games consoles and work stations. The X2380HS also has the two integrated speakers and is VESA mountable. It will provide excellent performance for photographic design, web design, standard office use and in multi-monitor environment.
Specification:-
- Diagonal: 23"
- Panel: IPS
- Display area h x w: 286.41 x 509.18 mm; 11.3" x 20"
- Response time: 5 ms
- Contrast: 1000:1 typical
- Contrast: 10,000,000:1 ACR
- Brightness: 250 cd/m² typical
- Brightness: 300 cd/m² max.
- Viewing zone horizontal/vertical: 178°/ 178°; right/left: 89°/ 89°; up/down: 89°/ 89°
- Display colour: 16.7 million
- Pixel pitch h x v: 0.2652 x 0.2652 mm
- Native resolution: Full HD 1080p, 1920 x 1080 ( 2.1 megapixel)
- Horizontal sync: 24 - 80 KHz
- Vertical sync: 56 - 75 Hz
- Synchronization: Separate sync
- Aspect ratio: 16:9
- Analog input connector: VGA (D-Sub)
- Digital input connector: DVI-D, HDMI
- HDCP: yes
- Speakers: 2 x 2 W (Stereo)
- Anti-theft-device Kensington-lock™ prepared
- Certificates: CE, TUV-GS, TÜV-Bauart, VCCI-B, CU, TCO 6
- Tilt angle: 22° up; 5° down
- VESA mounting: 100x100mm
- Warranty: 3yr
Was [£149.99] Inc. VAT
Only £129.95 inc VAT.
ORDER NOW
IIyama Prolite E2473HS 24" Widescreen LED Monitor - Black @ £129.95 inc VAT
The ProLite E2473HDS LED-backlit monitor, finished in the latest glossy-black, is a full high definition 24" display that features all the benefits this technology affords. The high specifications of the monitor include the 5,000,000:1 ACR, triple input connectivity (D-Sub, DVI-D, 2 x HDMI) and fast 2ms response for excellent sharpness in high definition video. VESA mount compatibility along with one HDMI input and headphone connector on the side of the cabinet ensures great comfort of usage.
Features:-
- Diagonal: 23.6"
- Panel: LED-Backlit
- Display area: h x w 293.2 x 521.3 mm; 11.54" x 20.51"
- Response time: 2 ms
- Contrast: 1000 : 1 typical
- Contrast: 5 000 000 : 1 ACR
- Brightness: 300 cd/m² typical
- Connections: D-Sub, DVI-D & 2x HDMI
- Viewing zone: horizontal/vertical: 170°/ 160°; right/left: 85°/ 85°; up/down: 80°/ 80°
- Pixel pitch: h x v 0.2715 x 0.2715 mm
- Vertical sync: 55 - 75 Hz
- Aspect ratio: 16 : 9
- 3yr On-site Warranty
ORDER NOW
Iiyama Prolite E2483HS-B1 24" Widescreen LED Monitor - Black @ £119.99 inc VAT
The ProLite E2483HS is an excellent 24” Full HD LED-backlit monitor with 1920 x 1080p resolution. It features 2ms response time and >5 000 000 : 1 Advanced Contrast Ratio, assuring clear and vibrant picture quality and high contrast. Triple Input support ensures compatibility with the latest installed graphics cards and embedded Notebook outputs. The E2483HS is also equipped with two high quality stereo speakers. Energy Star and TCO Certified, this monitor is a reliable solution for both home and office use.
Specification:-
- Diagonal: 24"
- Panel: TN LED-backlit
- Display area h x w: 298.9 x 531.4 mm; 11.5" x 20.5"
- Response time: 2ms
- Contrast: 5 000 000:1 ACR
- Viewing zone horizontal/vertical: 170°/ 160°; right/left: 85°/ 85°; up/down: 80°/ 80°
- Pixel pitch h x v: 0.277 x 0.277 mm
- Native resolution: Full HD 1080p,1920 x 1080 ( 2.1 megapixel)
- Horizontal sync: 30 - 80 KHz
- Synchronization: Separate Sync
- HDCP: yes
- Headphone connector: Yes
- Dimensions w x h x d: 565.5 x 412 x 203 mm
- Weight: 3.4 kg
- Warranty: 3yr
Was [£129.95] Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
Iiyama Prolite E2481HS-B1 24" Widescreen LED Super Slim Bezel Monitor - Black @ £131.99 inc VAT
The ProLite E2481HS is a 24’’ Full HD 1920 x 1080p LED-backlit monitor with super slim (7 mm) bezel. It features 2ms response time and >5 000 000 : 1 Advanced Contrast Ratio assuring clear and vibrant picture quality. Triple Input support of Analogue, DVI and HDMI ensures compatibility with the latest installed graphics cards and embedded notebook outputs. The monitor is Energy Star and TCO Certified. A reliable solution for all kind of work environments where best performance is desired.
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product. With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor. Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games. This LED monitor is equipped with two high quality stereo speakers. HDMI stands for High-Definition Multimedia Interface. Much smaller and more convenient than DVI, HDMI also has the significant advantage over DVI that it supports audio as well as video signals. When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that. VESA mount compliance means you can easily mount your monitor to a wall.
Specification:-
- Diagonal: 23.6"
- Panel: TN, LED-Backlit
- Display area h x w: 293.22 x 521.28 mm; 11.5" x 20.5"
- Viewing zone: horizontal/vertical: 178°/ 170°; right/left: 89°/ 89°; up/down: 85°/ 85°
- Pixel pitch h x v: 0.2715 x 0.2715 mm
- Input connections: VGA, DVI-D & HDMI
- Anti-theft-device: Kensington-lock™ prepared
- Certificates: CE, CU, TUV-GS, TCO
- Tilt angle: 21° up; 4° down
- Warranty: 3yr
Only £131.99 inc VAT.
ORDER NOW
Iiyama Prolite GB2773HS-GB1 144Hz 27" Widescreen LED 1MS Monitor - Black @ £259.99 inc VAT
The 27’’ ProLite G2773HS is a real game changer. The use of a high quality 144Hz panel with a blistering 1ms Response Time offers you an amazing gaming experience. The screen offers crystal clear, smooth and judder free graphics during fast paced games and beautiful quality HD video. Hardcore gamers will really appreciate the few milliseconds advantage this screen gives you, allowing split second game changing decisions. The screen comes equipped with stereo speakers and a headphone socket as well as HDMI, VGA and Dual Link DVI connections and boasts a 1920 x 1080 Resolution. The LED Back Light system offers great clarity and brightness.
iiyama has supported the Pro Gamer industry for over 5 years now and support gaming teams such as Team Dignitas (UK) and Low Land Lions (Holland), and are the monitor of choice for any discerning Gamer. iiyama continues to focus and support the vitally important competitive gaming industry , which is rapidly becoming one of the largest industries in the world, and gaming in general now out performs Hollywood in world wide revenue.
Features:-
- Height adjustable stand
- Diagonal: 27"
- Panel: TN, LED-backlit
- Display area h x w: 336.3 x 597.9 mm; 13.2" x 23.5"
- Response time: 1 ms
- Pixel pitch h x v: 0.3113 x 0.3113 mm
- Horizontal sync DVI: 30 - 140 KHz
- Vertical sync DVI: 55 - 120 Hz
- Analog input connector: D-Sub
- HDCP: yes
- Dimensions w x h x d: 647 x 454.5 x 239 mm
- Weight: 5.6 kg
- Height adjustable stand: Yes
- Height adjustment: 130mm
- Rotation (pivot function): 90°
- Swivel Stand: 90°; 45° left; 45° right
- Warranty: 3 Year On-Site
Was [£299.99] Inc. VAT
Only £259.99 inc VAT.
ORDER NOW
Iiyama Prolite X2783HSU-B1 27" AMVA Widescreen LED Monitor - Black @ £187.99 inc VAT
ProLite XB2783HSU - a 27” LED backlit LCD Screen featuring AMVA+ panel technology, guarantees accurate and consistent colour reproduction with wide viewing angles. Offering 24 bit ‘True Colour’ and great performance for displaying Black and White with the 3000:1 Native Contrast Ratio, means that the Prolite XB2783HSU will provide excellent performance for Photographic, Design and Web-design. The monitor features a height adjustable stand with PIVOT function making it also an excellent choice for Universities, Corporate and Financial Markets.
Specification:-
- Diagonal: 27"
- Panel: AMVA+ LED
- Display area h x w: 335.66 x 596.74 mm; 13.2" x 23.5"
- Response time: 4 ms
- Contrast: 3 000 : 1 typical
- Pixel pitch: h x v 0.277 x 0.277 mm
- HDCP: yes
- USB hub: UP 1 x USB 2.0 / DOWN 2 x USB 2.0
- Dimensions w x h x d: 622.5 x 400.5 (530.5) x 230 mm
- Weight: 6kg
- Warranty: 3yr
Was [£199.99] Inc. VAT
Only £187.99 inc VAT.
ORDER NOW
I don't need to tell anyone here how great iiyama monitors are, superb quality, superb looks and great warranty service, buy with confidence. :)
I was tempted by the 27 incher before the price reduction :)
Not found too much online about amva panels would this be anygood for gaming ?
Cheers
Cheers
Yes.
Iiyama are trying to combine good image quality and viewing angles of IPS, whilst still having a decent response time, hence 4ms. :)
Which version of the 27inch monitor do you have? In your description above, you title it as X2783HSU. but the description says XB2783HSU. On the web page, the title and manufacturers code says X2783HSU, but the picture is of a XB2783HSU. The description says XB2783HSU, and the text is from the XB2783HSU description on the Iiyama UK website.
The XB2783HSU-B1 is different from the X2783HSU-B1. Different stands and dot-pitch, amongst a few other things.
It's just the X not XB
That's a shame, the XB tempts me, the X... not so much. Any chance of getting the XB model in stock?
Here you go:-
Iiyama Prolite XB2783HSU-B1 27" AMVA Widescreen LED Monitor - Black @ £229.99 inc VAT
Specification:-
- Diagonal: 27"
- Panel: AMVA+ LED
- HDCP: yes
- Weight: 6kg
- Warranty: 3yr
Only £229.99 inc VAT.
ORDER NOW
Pricing is not final, should be not quite so much, but I can't get hold of iiyama for a price (weekend), so shall update price on Monday.
Thanks for looking into this. It's a tempting jack-of-all-trades monitor at a decent price. It's going on my Christmas shopping list.
My ProLite XB2783HSU arrived first thing this morning. Not bad as I only ordered it the day before.
Was a bit worried as the box had a bit of damage, took a picture of it unopened just in case. Need not of worried as everything was fine.
No dead pixels and a cracking picture. on a solid black screen I did notice a touch of backlight bleed. No worse then the dell 22" it replaced.
Overall for the price im more then happy. Very snazzy looking monitor in the flesh as well.
just received my Iiyama Prolite E2481HS-B1 24" monitor today and i got 2 dead pixels .
one is very small on left hand side and a red one just off centre .
what can i do !!!!
