** QUALIFYING AMD CARDS WITH 5 FREE GAMES INCLUDING BF4!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Our competitors don't have any 280X stock, OcUK does, our competitors are not giving away BF4 with so many cards, yet OcUK is and our competitors do not offer Ruby vouchers with graphics cards. Yet OcUK does, then combine the fact OcUK has the very best service, simply makes us the best.
Asus Radeon R9 290 "Voltage Unlocked" 4096MB GDDR5 PCI-Express Graphics Card @ £359.99 inc VAT
AMD Radeon R9 290 is a new graphics card powered by the latest AMD Radeon™ R9 290 graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290 also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:-
- Radeon R9 290
- GPU: Hawaii Pro
- Stream Processors: 2560
- Core Speed: 947MHz
- Memory Speed: 5000Mhz
- Memory interface: 512-Bit
- Memory capacity: 4096MB GDDR5
- Cooling: 2-Slot Blower Fan
- PCI-Express X16 lane required
- 750W or greater PSU required
- Power Connectors: 8-pin + 6-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Warranty: 3yr
Only £359.99 inc VAT.
ORDER NOW
Gigabyte Radeon R9 270X WindForce 3X OC 2048MB GDDR5 PCI-Express Graphics Card with BattleField 4 PC Game Included @ £164.99 inc VAT
GIGABYTE introduces the latest exclusive "Triangle Cool" Technology to reach a better cooling performance. The latest patent pending technology combines fin with clip module in a special triangle shape. With the original anti-turbulence structure plus the new triangle cooling design, it enhances the efficiency of heat dissipation dramatically by minimizing the flow of turbulence between fans. Therefore, the "Triangle Cool" Technology provides a more efficient air flow for the cooling system.
Ultra Durable VGA board provides dramatic cooling effect on lowering both GPU and memory temperature by doubling the copper inner layer of PCB. GIGABYTE Ultra Durable VGA can lower GPU temperature by 5% to 10%.
Ultra Durable VGA board reduces voltage ripples in normal and transient state, thus effectively lowers noises and ensures higher overclocking capability. GIGABYTE Ultra Durable VGA graphic accelerators improve overclocking capability by 10% to 30%.
Ultra Durable VGA board allows more bandwidth for electron passage and reduces circuit impedance. The less circuit impedance, the more stable flow of current and can effectively improve power efficiency. GIGABYTE Ultra Durable VGA can lower power switching loss by 10% to 30%.
Specification:-
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- Hugely overclockable
- Core Clock Speed: 1000MHz
- Boost Clock Speed: 1050MHz
- Shader Architecture: GCN
- Stream Processors: 1280
- Frame Buffer / Memory: 2GB GDDR5
- Memory Width / Speed: 256 bit / 5600MHz
- Power Connectors: 6-pin + 6-pin
- Display Outputs: 2x DVI + 1x DP + 1x HDMI
- Power: 180W TDP
- 3yr Warranty
Only £164.99 inc VAT.
ORDER NOW
Gigabyte Radeon R9 280X Rev2.0 WindForce 3X OC 3072MB GDDR5 PCI-Express Graphics Card with Battlefield 4 PC Game @ £275.99 inc VAT
Specification:-
- Rev2.0
- Black PCB
- Boost Clock Speed: 1100MHz
- Stream Processors: 32 CU / 2048 ALU
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 384 bit / 6000MHz
- Display Outputs: 1x DVI + 2x Mini-DP + 1x HDMI
- Power: 250W TDP
- 3yr Warranty
Only £275.99 inc VAT.
ORDER NOW
HIS Radeon R9 270X IceQ BOOST 2048MB GDDR5 PCI-Express Graphics Card @ £155.99 inc VAT
The card has the latest Boost Clock technology, providing extra performance for the most demanding games and applications!
IceQ ensures effective cooling when there is another card in front blocking the fan inlet, such as in CrossFire setup. By expelling the hot air, IceQ removes all the heat generated by the GPU out of the computer chassis, prevents the hot air from accumulating inside and enhancing the overall stability. The more crowded the chassis, the greater will be the impact. The demonstration shows that the IceQ does outperform the 3rd party cooler in closed environment. Cool air is drawn from both sides of the fan and hot air is forced out of the computer case. This ensures effective cooling when there is another card in front blocking the fan inlet, such as in CrossFire setup. The demonstration shows that the IceQ does outperform the 3rd party cooler in closed environment. Cool air is drawn from both sides of the fan and hot air is forced out of the computer case. This ensures effective cooling when there is another card in front blocking the fan inlet, such as in CrossFire setup.
Black hole impeller ensures large amount of cool air is ready. It draws cool air from both sides of the fan even there is another card blocking the fan inlet on the front.
PCB might easily warped due to prolonged hanging on motherboard & casing, potentially causing cracks on BGA solder joints and resulting in malfunctioning of the card. The HIS special metal rib provides extra strength to the PCBs to avoid warpage, making the cards extra stable and durable. You can count on HIS cards to game hard for 24/7/365 for years!
Specification:-
- Power: 180W TDP
- 2yr Warranty
Only £155.99 inc VAT.
ORDER NOW
Powercolor Radeon R9 280X 3072MB GDDR5 PCI-Express Graphics Card @ £259.99 inc VAT
Powercolor R9 280X has the performance to power the latest games with ease but at a very aggressive price point making it incredible value for money.
Equipped with a near silent cooling solution meaning you can game in near silence.
Specification:-
- Core Clock Speed: 850MHz
- Boost Clock Speed: 1000MHz
- Power: 250W TDP
- 2yr Warranty
Only £259.99 inc VAT.
ORDER NOW
Sapphire Radeon R9 270X Boost OC 4096MB GDDR5 PCI-Express Card @ £175.99 inc VAT
The "dual" in Dual-X refers to the two highly advanced cooling fans that are coupled with multi-heatpipe technology to cool mid-to high-end graphics cards. The fans are amazing: each blade boasts a sleek airfoil shape that increases cool air throughput so they can run slower. Even when you're pushing the processing power to the limits. Even when your're overclocking.
The quiet-running fans work with multi-heatpipes and heatsinks that take away heat from the processor to the fans. Plus, dust repelling bearings radically reduce failure caused by the build-up of dirt. In short, its a quiet, efficient way of cooling your graphics card - even when you're pushing it to the limits.
Specification:-
- Core Clock Speed: 1020MHz
- Core Boost Speed: 1070MHz
- Frame Buffer / Memory: 4GB GDDR5
- Power: 180W TDP
- 2yr Warranty
Only £175.99 inc VAT.
ORDER NOW
Sapphire Radeon R9 270 "BF4 Edition" 2048MB GDDR5 PCI-Express Graphics Card @ £149.99 inc VAT
Specification:-
- Core Clock Speed: 920MHz
- Core Boost Speed: 945MHz
- Power: 180W TDP
- 2yr Warranty
- FREE BF4 Voucher included
Only £149.99 inc VAT.
ORDER NOW
Powercolor Radeon R9 280X TurboDUO "BF4 Edition" 3072MB GDDR5 PCI-Express Graphics Card @ £269.99 inc VAT
Equipped with TurboDUO near silent cooling solution meaning you can game in near silence whilst keeping the card nice and cool.
Features:-
- Multi Phase Design: 8 Power Phases for improved OC ability
- Digital PWM
- Ferrite Core Choke: Decreases ripple to deliver more stable voltage
- DirectFET
- Patent GSG- Shape Heat Pipes Design: Reduces temperatures by upto 17% and noise reduction of upto 19%
- Pure Copper Base
- Backplate included
Specification:-
- Core Clock Speed: 880MHz
- Boost Clock Speed: 1030MHz
- Power: 250W TDP
- 2yr Warranty
Only £269.99 inc VAT.
ORDER NOW
Powercolor Radeon R9 270X DEVIL 3072MB GDDR5 PCI-Express Graphics Card @ £179.99 inc VAT
The Devil R9 270X is totally designed for enthusiastic gamers with factory overclock to 1150MHz, even up to 1180MHz with boost, delivering the most tremendous performance at its class. Also, the Devil R9 270X is equipped with 2GB of GDDR5, also with 1280 stream processors and high speed 256-bit memory interface, delivering excellent computing performance.
Devil R9 270X is built with Platinum Power Kit, which includes the most deluxe material like DirectFET, Digital PWM and 7+1+1 phases, dramatically improve total stability and reliable power delivery to GPU. The new Devil uses trio fans design, together with 4 units heat pipes and large surface of aluminum cooling fin, delivering 25% cooler and 18% quieter than reference.
To make Devil’s users feel more unique than others, we designed an exclusive interface for Powerup Tuner using Devil theme, also a Devil Gaming Pad, offering users a complete Devil package to choose.
Features:-
- Multi Phase Design: 7+1+1 Phases design enhances power efficiency and stability
- EMI Shell: Excellent interference suppression for high frequency and low leakage current.
- Digital PWM: Can work at higher frequency improving OC ability
- Super Capacitors: Excellent noise, temperature performance at GHz frequency, ultra low ESR.
- UHB: Featuring ultra high frequency which decrease ripple to deliver extreme stable voltage power.
- Efficient Triple fan design
- Includes Devil Gaming Pad
Specification:-
- Core Clock Speed: 1150MHz
- Core Boost Speed: 1180MHz
- Display Outputs: 2x DVI + 2x Mini-DP + 1x HDMI
- Power: 180W TDP
- 2yr Warranty
- Product Review 1: http://www.custompcreview.com/reviews/powercolor-devil-r9-270x-2gb-review/19285/
- Product Review 2: http://www.overclockersclub.com/reviews/powercolor_devil_r9_270x/
- Product Review 3: http://www.hitechlegion.com/reviews/graphics/37917-pc-270x-dev?showall=1&limitstart
Only £179.99 inc VAT.
ORDER NOW
VIEW ALL QUALIFYING 5 GAME FREE OFFER CARDS - HERE
Whatever happened to "not stocking PowerColor due to their rma being in Asia area"? :D
We've done a special deal, which I shall announce sometime next week.
In short they have given us pretty much the best possible RMA service compared to any vendor and exclusives. :)
Plus look at some of the newer products, black PCB, Digital PWM's, Backplates, sexier designs.
We never burn a bridge. ;)
Few others have stated that their rma process is a lot better now as they have a europe RMA base.
With OcUK it is via OcUK and an advanced 48hr swap out, we have the best terms. :)
Shall make an official announcement next week. :)
The Devil 270X has to be the most impressive 270X I've seen yet, right up there with the Sapphire Toxic.
What are the other 4 games? I think I'm being blind but I can't find any info other than BF4 :P
Also, out of the 280's, which is the best cooler? I've heard about the 280/290 running pretty hot so if I was to buy one I'd like the best cooler I can get on it...
Gigabyte WindForce 3X is pretty much regarded as the best combination of both low noise / cooling ability. :)
The other 4 games is the AMD RUBY code which shows under free items on the product page, if its not there its not a qualifying card. You can then choose 4 games from the AMD Store. :)
Yeah I looked at the Windforce and thought it looked pretty nice at the same time too.
Good stuff, Cheers Gibbo! How long will this offer last?
Is the Devil 270X 2GB or 3GB? The title says 3GB and the description (and Powercolor's website) says 2GB - typo?
I'm stuck between the 270X's but if the Devil is the best I'll go for that. Shame about the pre-order though, I was hoping to get a play on it next week as my desktop is at uni in Sheffield but I am returning home to Stoke on the 20th, might pick it up on the way home!
It's a 2GB card, shall get that corrected.
